Help!!!!!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 30th, 2006, 01:41 PM   #1
ouchman
ouchman's Avatar
Send a message via Yahoo to ouchman Send a message via Skype™ to ouchman
Default Help!!!!!!
will the head off a 94 lsi tracker work on a 90 tracker?
both r 1.6l i used the 90 intake, exhaust manifold,
and cant get it to run, checked the timming several times,
the cam sprocket has 2 marks where the head off the 90
only has 1 any help will be a god sent
...thanx
support the sport- www.GLFWDA.org - member
Dear Travelers,
You won't see London and you won't see France, until we see your underpants!
Sincerely, TSA Officers
ouchman is offline   Reply With Quote
Old January 30th, 2006, 08:29 PM   #2
scottie
Eye candy
scottie's Avatar
...thanx
remove timing belt, rotate crank 180 degrees, its a 2:1 ratio. so there you go.
then hope the pistons don't "interfere" with the valves
there is also a way you could check it by looking at the rotor and knowing when cyl #1 is at TDC if you are 180 degrees off .
Old January 31st, 2006, 09:21 AM   #3
Mclovin
"The Situation"
Mclovin's Avatar
remove #1 spark plug. put your finger over the hole rotate crank til u feel pressure then move to TDC.... (like everyone didnt know that already)
Old January 31st, 2006, 11:59 AM   #4
ouchman
ouchman's Avatar
zook94 called it and saved the day, i'm back mobile
Dear Travelers,
Old February 1st, 2006, 12:17 PM   #5
zook94
Resident Jerkoff
zook94's Avatar
Location: Saginaw, Michigan, USA, North America, Earth, Milky way
Time of death: 11:24 AM........
zook94 is offline   Reply With Quote
Page generated in 0.21415 seconds with 38 queries
