4.3L acting strange - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 4th, 2007, 12:47 PM   #1
scorpio_vette
scorpio_vette's Avatar
Send a message via MSN to scorpio_vette Send a message via Yahoo to scorpio_vette
Default 4.3L acting strange
got a 95 s-10 with a 4.3L Z motor. under hard acceleration (like punching the pedal completely from a dead stop) it stumbles and for a second almost sounds like the engine shut off. even while driving if you gun it, it will just stumble. but as long as you apply slow steady throttle, it drives fine.
we did a tuneup (plugs, wires, cap, rotor) and checked the cat for any problems (we temporarily removed it and still have the same problem).
i also noticed something else that's really strange. with the scan tool hooked up and the engine at idle, the computer shows that it's running at between 9,000-9,999 RPM. the engine idles just fine at what i would guess is around 700-800rpm. so how do i explain the 9,999RPM, and could that be related to the stumble on hard acceleration???
scorpio_vette is offline   Reply With Quote
Old April 4th, 2007, 01:00 PM   #2
jeepguy74
jeepguy74's Avatar
i had a similar prob and it was the fuel pump and filter
no idea in the 9000 rpm idle
Old April 4th, 2007, 01:05 PM   #3
Sinister Minister
Sinister Minister
Sinister Minister's Avatar
yeah, I would try the filter first and if it still does it, it is more than likely the pump.
Sinister Minister is offline   Reply With Quote
Old April 4th, 2007, 01:05 PM   #4
bellmer
bellmer's Avatar
i dont think u would have much of and engine when u hit 10k rpm. but yea fuel filter and fuel pump. mine did the same thing to when i was driven up to petoskey once
bellmer is offline   Reply With Quote
Old April 4th, 2007, 01:18 PM   #5
max5p33d
slack jawed faggot
max5p33d's Avatar
Send a message via ICQ to max5p33d Send a message via AIM to max5p33d Send a message via Yahoo to max5p33d
Tps?
max5p33d is offline   Reply With Quote
Old April 4th, 2007, 01:19 PM   #6
scorpio_vette
tps reading seem to be within spec.
i was thinking of doing to filter/checking supply pressure since it seemed to be acting like it's starving. but the 9,999RPM is really throwing me off on what to think.
Old April 4th, 2007, 04:01 PM   #7
user name
keep your stick onthe ice
user name's Avatar
my first thought was TPS before I read the 9,999 rpm part you sould find out were the pcm gets it's tac input from and search that part out before tossing parts at it. Fuel pumps are very common for failing in the 100,000-140,000 mile range.
Old April 4th, 2007, 06:03 PM   #8
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
if you have a electric shift trans its got a trans rpm sensor that acts like a tach. that could be the problem. it might not be a stumble but the trans hanging up before you accellerate.
Yetti
Old April 4th, 2007, 06:05 PM   #9
steveo
In the band!
i would like to see a 4.3 at 10k. that would be cool!!
Old April 4th, 2007, 06:08 PM   #10
Yetti
Yetti's Avatar
...can you say "Grenade!"
Yetti
Old April 5th, 2007, 12:31 AM   #11
ricdawg
ricdawg's Avatar
Scorpio.... Sounds like the EGR valve is opening up causing a lean miss. It probably has the computer controlled vacuum switch and either vacuum is getting past it or the computer thinks it's cruising down the road (due to the RPM problem and WOT when you punch it) and tells it to open up to lean out tail pipe emissions.
Rick
ricdawg is offline   Reply With Quote
Old April 5th, 2007, 07:31 AM   #12
steveo
In the band!
thats something they would do on mythbusters, then hide behind plexiglass. i have blown up alot of stuff, and the best i ever had to hide behind was an igloo cooler.
Old April 5th, 2007, 08:17 PM   #13
scorpio_vette
well i was sick today and had to stay home, but my body shop tech went ahead and put a new fuel filter on since i told him to make sure there were no fuel restrictions. he called me up and said that the truck runs fine now and squeals the tires again and takes of nicely when he stomps it. as far as the 9,999 RPM, i'll have to look into that some more when i get back and see what i can find. that is kinda interesting.
Old April 6th, 2007, 12:15 AM   #14
max5p33d
slack jawed faggot
max5p33d's Avatar
"my body shop tech went ahead and put a new fuel filter on since i told him to make sure there were no fuel restrictions. he called me up and said that the truck runs fine now and squeals the tires again and takes of nicely when he stomps it."
I hope your paying him good cash to beat the crap out of your truck!
Hahaha, just kiddin. Maybe i had too many beers.
Old April 6th, 2007, 10:48 AM   #15
scorpio_vette
it's his truck, so he can do what he wants with it. lol but yes he does beat on my jeeps quite often. i let him drive my XJ very often for parts runs and stuff, and he fell in love with it and has been looking for one for himself. and now i let him drive my 84 grand wagoneer, and now he wants one of those too. lol he's never been in a jeep, and after driving my XJ, TJ and grand waggy, he fell in love with them. lol
Old April 7th, 2007, 10:21 PM   #16
blackcat818
Send a message via AIM to blackcat818
Ignition switch is going bad...not enough power going to the coil.
Ignition switch is about $100.00, and at most should take about 1 1/2 hours to replace.
Same thing happened to us, and we have the same model and year. Ours was stumbling, the trans wasn't shifting correctly, and it was all due to low voltage of the computers.
blackcat818 is offline   Reply With Quote
Page generated in 0.34634 seconds with 71 queries
