wheel hub help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 3rd, 2007, 07:22 PM   #1
lovemychevy
Something Clever
lovemychevy's Avatar
Default wheel hub help
I have a 1995 escort. ineed to get the hub off to have a new bearing pressed in I got the nut off but now can't get the hub off any suggestions. do i need to take the whole knuckle of?
lovemychevy is offline   Reply With Quote
Old April 3rd, 2007, 10:40 PM   #2
max5p33d
slack jawed faggot
max5p33d's Avatar
Send a message via ICQ to max5p33d Send a message via AIM to max5p33d Send a message via Yahoo to max5p33d
Cant get the hub off the CV shaft?
Murrays has a loaner tool system. DO NOT use a hammer and socket.
You can borrow the proper tool free. All they want is a deposit.
max5p33d is offline   Reply With Quote
Old April 3rd, 2007, 10:44 PM   #3
Freak
Wheelin the HD
Freak's Avatar
Ive always used a hammer, but in some cases I've used a 3 arm puller (4x4 2500 GM with the DUMBEST front rotator set up I have ever seen)
Old April 3rd, 2007, 11:04 PM   #4
chris1044
chris1044's Avatar
X2 on the special tool.....you need something like this - the hub shark
I'm pretty damn sure thats how the older escort hubs are set up.....may be wrong though. If it is set up like this, I dont even know how you'd use a hammer...it's not a unit-bearing set up IIRC
Old April 4th, 2007, 07:52 AM   #5
max5p33d
slack jawed faggot
max5p33d's Avatar
The 3 arm pullers can be dangerous IMO. I hope you use gloves and eye protection.
Most of the time the hub is soo seized that the puller kicks sideways and sometimes breaks the arm. That acts like a slingshot and can maybe even break your hand.
Good luck.
Old April 5th, 2007, 02:28 AM   #6
junk90xj
ALLPRO AUTO
junk90xj's Avatar
yes pull the hub and press it in.
http://www.apalansing.com/
Page generated in 0.20615 seconds with 41 queries
