S 10 strait axle conversion - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 2nd, 2007, 09:21 PM   #1
Badphish
Default S 10 strait axle conversion
Has anyone done this conversion? What axle did you use what leaf springs did you use. What steering did you use again the jeep looks fairly strait forward. I've done some research and jeep axles seem the easiest and cheapest but the d30 is fairly weak and most have less than desirible gearing. What would you recomend I'm looking and running 33 inch tires or less.
Badphish is offline   Reply With Quote
Old April 2nd, 2007, 11:40 PM   #2
Kawierider
Kawierider's Avatar
If it was me I'd run a HP d30. For 33 in and less tires an upgraded alloy shaft would be plenty strong....if your running high HP you might wanna go d44 but I wouldn't spend the money.
From what i've read on a couple of good write-ups on pirate4x4 you can run a HP d30 from a cherokee, the cherokee steering linkage, and a 2wd s10 pitman arm. If you go this route you will need to get creative with suspension links but thats not too tough.
You could run a D30 from a yj with similar results. Just use leaf springs instead.
Old April 3rd, 2007, 08:07 PM   #3
Badphish
thats the direction i'm looking at going is the d30 with leafs will have to check out pirate thanks
Old April 10th, 2007, 11:52 AM   #4
4-PLAY
4-PLAY's Avatar
I did mine but with 3/4 ton axles.
There are lots of different ways and parts.
Just take your time and work through the bugs.
(Look at one that is done already and copy it):tonka:
4-PLAY is offline   Reply With Quote
Page generated in 0.24226 seconds with 35 queries
