dodge cummins problem. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 2nd, 2007, 08:22 PM   #1
steveo
In the band!
Default dodge cummins problem.
anyone here know about cummins? i am having a problem with my 2003.5 cummins. it only revs up to 2200 rpm, and its at WTO the whole time. the voltage on the throttle sensor reads at 3.5v. any thoughts on how i can get this to work? PS this motor is in a 98 chevy 2500.
Old April 2nd, 2007, 09:00 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I am wondering if you used the drive by wire engine? and if so did you use the chevy pedal assem?
Yetti
Old April 2nd, 2007, 09:05 PM   #3
steveo
In the band!
the pedal is chevy. i am not 100 percent sure if its a drive by wire.i havent worked on it since last fall, my dad is finishing the job now. it runs good, shifts great, but it just wont rev up past 2200 rpm.
Old April 2nd, 2007, 09:13 PM   #4
Limp-home mode?
Old April 2nd, 2007, 09:16 PM   #5
steveo
In the band!
it goes into wot, but to climb in rpm's you gotta hold it to the floor. also does anyone have a voltage book for this engine? we bought 2 boxes full of manuals and none of them tell the voltage this thing needs.
Old April 2nd, 2007, 10:37 PM   #6
merr6267
More boost than yours:)
merr6267's Avatar
www.dieseltruckresource.com
Anything you need to know can be answered there. My guess is the lift pump, which will fry the injection pump. Although I'm not sure which year was the cutoff for the VP-44 pumps.
Use the search at the link I gave you, and if you can't find an answer, make a post asking. You'll get it sorted out.
Take care,
Phill
merr6267 is offline   Reply With Quote
Old April 3rd, 2007, 07:19 AM   #7
steveo
In the band!
thanks guys. we have a years time and alot of money invested in this and to get this close only to have it not work is giving me ulcers.
Old April 3rd, 2007, 07:53 AM   #8
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Not to nit pick, but diesels are WOT all the time.
@clarkstoncracker
Old April 3rd, 2007, 09:36 AM   #9
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
hahahahahahhahahahahhahahahaahah
the money shot
I'm guessing its not the lift pump. Check all of your sensors. Shoulda swapped a 12v, they run soooo much easier..
Old April 3rd, 2007, 09:37 AM   #10
Hacksaw
Hacksaw's Avatar
the money shot
www.cumminsforum.com
www.dieselgarage.com
www.turbodieselregister.com
Old April 3rd, 2007, 09:41 AM   #11
noodles
give 'er sh*t ay?
noodles's Avatar
it wont go past 2200? if so thats the high speed gov. its wrote in to the comp that way. there are limits the cummins dealers can install on the comp to make it so they dont over speed.
Old April 3rd, 2007, 10:37 AM   #12
steveo
In the band!
computers been reprogrammed, and not by a dealer
Old April 3rd, 2007, 10:38 AM   #13
steveo
In the band!
the money shot
dude this motor is balls. i cant wait until we get this thing repainted and running good. we did such a good jop people are asking us to do theirs for them.
Old April 3rd, 2007, 12:21 PM   #14
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
:tonka: :tonka:
Maybe he installed a tractor motor and that's all it will rev.
Old April 3rd, 2007, 12:24 PM   #15
steveo
In the band!
no, its from a wrecked 2003 dodge, it has the dodge transmission and transfer case too.
Old April 3rd, 2007, 07:26 PM   #16
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
FWIW, the pedal sensors I use in my development cars are 0-5V.
@clarkstoncracker
Old April 3rd, 2007, 08:40 PM   #17
Then I'd get a dodge factory service manual and use that to troubleshoot your sensors. That should be your starting point.
I agree with Hack, I prefer the 12 valve motors. Used to pull a 28,000lb tub grinder with one of ours.
Old April 3rd, 2007, 08:47 PM   #18
steveo
In the band!
the old man says he thinks the engine is not getting a speed signal from the transmission. its a 2003 it doesn't have anvp-44 injection pump. also thinking we got a problem with the pcm not working with the ecm.
Old April 3rd, 2007, 08:54 PM   #19
steveo
In the band!
at full throttle the pedal sensor is showing 3.7 volts at 100%
Old April 3rd, 2007, 08:56 PM   #20
steveo
In the band!
Page generated in 0.43234 seconds with 83 queries
