Np205 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 29th, 2006, 05:15 PM   #1
bigblue2230
still goin
bigblue2230's Avatar
Default Np205
This is an NP205 from a 79 f-250 that attaches to a C-6 transmission. I am not sure what else it will bolt up to, but it is a driver side drop. It uses a CV style drive shaft where it bolts up to the transfercase for the front drive shaft. I will throw in the front driveshaft if you need it. 75 dollars o.b.o. In good working condition.
bigblue2230 is offline   Reply With Quote
Old January 29th, 2006, 11:27 PM   #2
wrath
Project Antitube
wrath's Avatar
Send a message via AIM to wrath
You ever drive through Owosso?
wrath is offline   Reply With Quote
Old January 30th, 2006, 07:10 AM   #3
bigblue2230
still goin
i could be passing through there in a couple weeks.
Old February 3rd, 2006, 10:16 PM   #4
wrath
Project Antitube
wrath's Avatar
How clean is it? I'm mostly worried about it being dry from all the gear oil leaking out rather than being dirty. So far, that's the only way I've seen a 205 fail. Not like 203s where they have catastrophic failure.
If you still have it and you want to stop at my parents' on M52 in Owosso and drop off the transfer case and the driveshaft I'll make sure they have $75 for you.
Old February 7th, 2006, 06:09 PM   #5
bigblue2230
still goin
i capped off the end of it and it still has some fluid inside of it. No water should have gotten in, but i will let you inspect it for yourself and if it is not up to your standards, then we can figure out what we are doing next. I wouldn't be passing through until this sunday sometime, so pm me some directions and i'll get it to you.
Page generated in 2.03913 seconds with 38 queries
