yj problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 29th, 2006, 12:28 PM   #1
muddslinger
muddslinger's Avatar
Send a message via AIM to muddslinger
Default yj problems
95 yj 2.5L
1. for the past 2 weeks, i have had massive mpg loss. i dont even know what im getting around city right now but i went up north friday and got about 13-14 mpg highway and usually get like 16-17, then on the way home today i got about 8-9 mpg highway. so what is up with that?
2. on the freeway home today i had a huge problem keeping speen, it was kind of off and on. i would be going fine in 5th, then i would loose alot of powere and my speed would decrease even with my foot to the floor. then i would put it in 4th very slowly get up to speed, put it in 5th and repeat. but then after awhile it would go back to normal. ???
muddslinger is offline   Reply With Quote
Old January 29th, 2006, 06:09 PM   #2
BigBlkYJ 355
U-Joints Fear Me
BigBlkYJ 355's Avatar
maybe a dirty fuel or air filter? bad injector? is the check engine light on?
Old January 29th, 2006, 06:52 PM   #3
87'YJ
Jeeps, Journey and Jesus
87'YJ's Avatar
Mine did the same thing and it turned out to be the fuel pump. (its an $18 part from murrays, very easy to replace, but hard to diagnose if it is not pumping at 6 PSI).
I would change the fuel filter first just to see if that is the problem.
Then of course, it could be electrical, but thats another issue
87'YJ is offline   Reply With Quote
Old January 29th, 2006, 07:52 PM   #4
muddslinger
bigblkyj- fuel filter is realitivly new and same with air filter. lights not on
87'yj- fuel filter is good, mabey it is the fuel pump.
Old January 29th, 2006, 09:41 PM   #5
87'YJ
87'YJ's Avatar
pull off the fuel hose right before the fuel filter and turn the jeep over. See if there is fuel pumping. It should be a strong steady stream. If it is weak, or not pumping, it is your fuel pump. the symptoms you described are the exact same thing that I had go wrong with my jeep a while back.
Old January 29th, 2006, 10:55 PM   #6
Tonka
Tonka's Avatar
fuel pump for a 95 will run $100+
Old January 29th, 2006, 11:14 PM   #7
Mclovin
"The Situation"
Mclovin's Avatar
yea. 87'Yj there prob has a carb. motor which has a lil cheapy 6-8 psi pump..
Old January 29th, 2006, 11:21 PM   #8
clarkstoncracker
lol
clarkstoncracker's Avatar
If you end up needing a fuel pump, I have 2 working ones in the barn .
Old January 30th, 2006, 06:54 AM   #9
muddslinger
alright thanks cc, ill check it out and let you know
Old January 30th, 2006, 10:39 AM   #10
Gunsworth
Gunsworth's Avatar
This may sound stupid, but have you checked your brakes? Mine started doing this exact same thing and when I went to change my brakes I found that both calipers were sticking/dragging.
Old January 30th, 2006, 01:47 PM   #11
Mclovin
"The Situation"
Mclovin's Avatar
Check your Catalytic also theyc can cause poor MPG and performance.. run a back pressure check
Old January 30th, 2006, 01:55 PM   #12
Monster4.0
Monster4.0's Avatar
I would scan it for codes first, but O2 sensors, and coolant temp sensors(the front one) both make it run rich when they go bad.
Old January 30th, 2006, 02:58 PM   #13
muddslinger
no cat so that has nothing to do with it.
gunsworth- my rear brakes are screwed up, i was planning to take it into my automechanics class this week or next to replace a bunch of stuff on the rear brake assembly so i guess that could be it.
monster4.0- if you mean scan by using the idiot light, its not on. o2 sensor was recetly replaced so it shouldnt be that.
Old January 30th, 2006, 03:13 PM   #14
Monster4.0
Monster4.0's Avatar
I was thinking the autozone free scan, but cycling the key front to back three times works also.
Old March 2nd, 2006, 06:30 PM   #15
muddslinger
so i did a compression test and compression is fine, what else could it be that would cause that shitty of mileage
Old March 2nd, 2006, 07:29 PM   #16
shawn
Resident HVAC/R Jambi
shawn's Avatar
So what is your problem? Just shitty gas mileage? Well, the weather for one, the type of gas in the pumps for two, your running 31's for 3, it's a jeep for four.
Old March 2nd, 2006, 07:30 PM   #17
shawn
shawn's Avatar
Is this a 4cyl or 6cyl? Have you done a recent tune up?
Old March 2nd, 2006, 08:08 PM   #18
BlooMule
Old School
BlooMule's Avatar
First post sez it's a 2.5 4 popper
Did the problem show up after putting on the 31's? My 89 became a complete dog after going bigger in the tire department. I went to 4.88's and not only did my mileage jump (mathematically corrected by distance check) but I also can PASS people on the freeway....these litlle motors like a lot of gear.
-rw-rw-rw
Old March 2nd, 2006, 09:36 PM   #19
muddslinger
they problem is new, it jsut started a few weeks ago, the tires have been on ther for a long time. tune up in the fall. fuel filter a couple weeks ago. i cant imagine gas would be this bad from weather. i mean this is significant, im getting under 10 mpg city and about 11-12 highway, i used to get about 16-17 highway.
Old March 2nd, 2006, 10:51 PM   #20
BMFmike
meh.
BMFmike's Avatar
I have seen this problem many times
Your toe-nails are stuck in the radiator, it happens when you are young.
Page generated in 0.30089 seconds with 83 queries
