Noise - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 30th, 2007, 05:02 PM   #1
welder_48340
Send a message via Yahoo to welder_48340
Default Noise
I seem to have a whining noise when I step on the gas. It quits if I push in the clutch. Sounds like its coming from the differential rear. Any ideas guys thanks Bob
welder_48340 is offline   Reply With Quote
Old March 30th, 2007, 05:11 PM   #2
PavementPounder
PavementPounder's Avatar
Check the fluid level.
Old March 30th, 2007, 06:15 PM   #3
welder_48340
I did and that is not an issue. Thanks though
Old March 31st, 2007, 02:14 AM   #4
PavementPounder
What's your pinion angle look like relative to the driveshaft?
Also, are your u-bolts tight? If they are allowing your axle to shift a bit, it could have led to some premature wear on the pinion bearing.
Old March 31st, 2007, 05:46 AM   #5
welder_48340
Thanks will check that out.
Old April 2nd, 2007, 07:39 PM   #6
junk90xj
ALLPRO AUTO
junk90xj's Avatar
throw out bearing for the clutch?
http://www.apalansing.com/
Old April 2nd, 2007, 07:46 PM   #7
kevinr839
kevinr839's Avatar
Sounds like a pinion bearing or differential bearings.
kevinr839 is offline   Reply With Quote
Old April 3rd, 2007, 04:40 AM   #8
welder_48340
Thanks you all it was the pinion bearing. I appreciate the input guys. Happy wheeling
Page generated in 0.13551 seconds with 47 queries
