1987 4runner 4 wheel drive not engaging. Help. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 29th, 2007, 08:51 PM   #1
Denton
Brush Yo Teeth!
Denton's Avatar
Default 1987 4runner 4 wheel drive not engaging. Help.
I have a 1987 4runner with 214,000 on the clock. When I first got it every time I put it in reverse then went foward the 4 wheel drive would try to engage and make a horrible clunking noise. I would have to pull over and shift the transfercase lever through the ranges to get it in 2 wheel. Now I cant get the 4 wheel drive to engage regardless of what I do. I was thinking it could be my automatic locking hubs. Any other thought? Thanks!
Denton is offline   Reply With Quote
Old March 29th, 2007, 09:03 PM   #2
Yes, sounds like an issue with the locking hubs.
Old March 29th, 2007, 09:20 PM   #3
hman1991
hman1991's Avatar
Send a message via AIM to hman1991
auto lockers suck. get some manual ones.
hman1991 is offline   Reply With Quote
Old March 29th, 2007, 09:29 PM   #4
Denton
Brush Yo Teeth!
Denton's Avatar
is it hard to change over? Does it cost alot? I have never done locking hubs before, but I am pretty handy.
Old March 30th, 2007, 10:25 AM   #5
87yotafoo
most of time just swap them out of a manual hubbed truck. Nothing hard to it. Just becareful cuz those bolts like to break alot. PB blast all them several times prior to taking them off. pull it style junkyard, they are cheap to get off a truck. I might have some for sale too.
87yotafoo is offline   Reply With Quote
Old March 30th, 2007, 08:53 PM   #6
Denton
Brush Yo Teeth!
Denton's Avatar
So are the manual hubs off the pickups interchangable if so what year range?
Old March 30th, 2007, 09:08 PM   #7
Mud'N'Truck
I'll Finsh One, One Day
Mud'N'Truck's Avatar
Just find a 86 to 94 truck or 4runner with manul hubs. Just take off the whole hub assamble and swap them out.
Old March 30th, 2007, 09:14 PM   #8
Denton
Brush Yo Teeth!
Denton's Avatar
Thanks. Going to the yard tomorrow. I let ya know if I find anything!
Old March 31st, 2007, 09:34 PM   #9
Denton
Brush Yo Teeth!
Denton's Avatar
Found some on a 90 toyo pickup. I could not get those stubborn things off. I took all the bolts off, took the plastic cover off and removed the one bolt connecting it to the stub shaft...I pounded on them forever.Is there a trick to getting the manual lockouts off? My automatic locks just popped right off.
Old March 31st, 2007, 10:02 PM   #10
OK, were there bolts, or nuts?
Assuming you removed nuts, and the studs are still there, then you have to remove the cone washers. They are evil, and usally refuse to come off. The best thing I know of is an air chisel with a round poitn on it, it vibrates them out.
Manual hubs do swap, but at least on olid axles, theres another piece or two that need to go on, too. Its late now, I forget exactly what(too many welding fuses today). I believe one or two of the washers in the hub are needed.
Old March 31st, 2007, 11:52 PM   #11
Denton
Brush Yo Teeth!
Denton's Avatar
They were nuts that I took off. I am not sure about the cone washer? I guess I didnt see that..I think I should go buy a book ...lol
Page generated in 0.26116 seconds with 56 queries
