C-6 Trans and 203 transfer case. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 26th, 2007, 09:55 PM   #1
jackal
jackal's Avatar
Default C-6 Trans and 203 transfer case.
so as the title says i have a c-6 trans and a 203 transfer case. now i have 2 questions here. first and the most important one. i replaced my 203 transfer case because when i bought it, the chain had snapped and broken all the spider gears. after i got the t-case up in there, i drove it around and ive got a HORRIBLE leak from where the t-case bolts up to the tranny. now i have been told 2 different things here. one : there is a seal in the back side of the transmission and i need to replace that, however, every place that i call doesnt have that in stock. two : there is a gasket in between the transfer case and the transmission and no seal in the back side of the trans, only in the t-case. i really need to know what is the proper thing here and how i should go about fixing it. should i just drop the t-case and see what ive got going on here? thanks for any help guys, its greatly appreciated.
now onto the second issue that isnt so big of a deal. this is a 79 bronco and eventually, i want to put a 205 t-case in it. once again, ive been told two different stories. one : it will bolt up, no problem. two : it wont bolt up. lol, obvisoioly im awful confused here. im just getting into the mud bogging and i dont know A LOT about trucks, but i know enough to get by. this kind of stuff though is a little out of my league. once again, thanks for any help you guys can offer.
Tony
jackal is offline   Reply With Quote
Old March 26th, 2007, 10:30 PM   #2
TurdBronco
There is a gasket (or rtv) that goes between the adapter and trans. If you fawk this up or use nothing, it will leak alot.
A 205 will bolt right up to the adapter, however, you will have to use the 205 tcase mount that bolts to the frame. I think the 203 is much larger so the driveshafts might not be the correct lengths.
Old March 26th, 2007, 10:47 PM   #3
jackal
jackal's Avatar
so just that i got this right, there IS NOT a seal in the rear of the transmission???
one more stupid question, what is the shift pattern in a 203??? my shifter is really messed up and i cant make out anything.
Old March 26th, 2007, 11:18 PM   #4
TurdBronco
not that i know of. Trans fluid is in the adapter right, so what would the seal do? As far as i know its just open in the back.
I dunno the shift pattern of a 203
Old March 27th, 2007, 07:03 AM   #5
IDIeselman
IDIeselman's Avatar
Yup,what he said!
Old March 27th, 2007, 09:26 PM   #6
jackal
jackal's Avatar
well i went over there today and pulled the t-case again, bought some rtv and made a gasket. put all that in there and got it back together. this weekend ill go over there again and take some tranny fluid to make sure that its not leaking. i didnt have the extra cash today or i would have already done it. still need to know the shift pattern of my 203 though if anyone can help. it would be greatly appreciated..thanks in advance!
Page generated in 0.17686 seconds with 41 queries
