HP60 spindle removal - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 24th, 2007, 08:34 PM   #1
Jsawduste
Jsawduste's Avatar
Default HP60 spindle removal
Anyone have any tricks to removing a set of stuck dana HP 60 spindles ?
Yes the bearings are off and so are the nuts. Axle has seen some road salt so I figuring there is a bit of corrision behind them.
Soaked the outside in PB Blaster and will let them sit overnight.
Gotta be a way to do it without destroying parts.
Do`nt have a source for heat other then a propane torch.
Thanks
Jsawduste is offline   Reply With Quote
Old March 24th, 2007, 08:41 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
What year? If it has bolt on caliper brackets I usually will hit the back of them to free it up. If not a block of wood on the end of the spindle an hit it up and down. I found a dead blow hammer use full once it was loosened up, it won't mess up the threads.
Old March 24th, 2007, 09:21 PM   #3
Jsawduste
Jsawduste's Avatar
The axle is a 93 F350 that had the split pins holding on the calipers.
Thanks again for the help.
Old March 25th, 2007, 08:03 AM   #4
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
you can use the block method, just don't hit on the spindle directly with a hammer. Beat i side to side up and down until you can get a screw driver to start on one side. Then tap back to the screw driver side t help it pull the spindle out.
I have an OTC spindle socket that is used with a slide hammer to pull them off. Been along time since I used the hammer method good luck.
Old March 25th, 2007, 10:38 AM   #5
Newimagelawns
I like coolant
Newimagelawns's Avatar
x2 on the spindle socket. I messed around for a while trying to pry it off. Spindle socket makes it a helluva lot easier. The only problem is trying to find one. I had to order one but it only took a day, $40 bucks i think.
Newimagelawns is offline   Reply With Quote
Old March 25th, 2007, 04:03 PM   #6
Jsawduste
Jsawduste's Avatar
Went to a couple different auto parts stores. None of them had any type of slide hammer tool. Tried to explain what i wanted but they just kept going back to the BFH route.
Thanks for the help though guys. What I ended up doing was getting a RBFH (Really Big F'ing Hammer) and whacking the snot out of `em. They are off now and I gots a RBFH for doing the tie rods and ball joints now.
Thanks again
Page generated in 0.24532 seconds with 41 queries
