Whiny Sploder - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 26th, 2006, 07:25 PM   #1
Arnie897
y=mx+b
Arnie897's Avatar
Send a message via AIM to Arnie897
Default Whiny Sploder
My 5 speed is whining in 1, 2, 3 and 5th gears. Any idea what may be causing this and how long I will be able to drive before total driveline meltdown?
Arnie897 is offline   Reply With Quote
Old January 26th, 2006, 07:39 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
well do a couple of tests. if the whiny noise goes away in forth gear at speed then its a mainshaft bearing problem. if its still the same in every gear then I would say its a counter shaft problem. check your fluid level and fill it up to the top of the fill hole. it could be enough to stop the noise for a bit
Yetti
Old January 26th, 2006, 08:55 PM   #3
Arnie897
y=mx+b
Arnie897's Avatar
Very quite in 4th. Drained and refilled when the noise started. Do you think an additive might help the noise or should I just bite the bullet?
Old January 26th, 2006, 09:31 PM   #4
shawn
Resident HVAC/R Jambi
shawn's Avatar
Hmmm, 4th is the only gear that is 1:1, therefore doesn't use the countershaft. I wonder if those needle type bearings between the 2 mainshaft halves are going bad.
Old January 26th, 2006, 10:42 PM   #5
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
sure crazyjeep just hasnt been riding shotgun? that might explain the whiny noises..
I KID! I KID!
nixxerRsixxer is offline   Reply With Quote
Old January 27th, 2006, 06:22 AM   #6
Arnie897
y=mx+b
Arnie897's Avatar
wha wha wha.....Also, I see that your Jeep project is coming along quite well....
Anyone one here ever tried one of those eBay rebuilt transmissions? I'm just wondering how the quailty compares to one rebuilt locally.
Old January 27th, 2006, 06:35 AM   #7
Yetti
Yetti's Avatar
given that its quiet in 4th tells me you have a bearing issue. you could pull the trans and re-shim the input spline bearings and tighten the clearence over the whole main shaft. that wat you don't have to tear apart the whole trans, its a bit tricky because you don't want to remove the front shaft, just the holder . then add about .015 shim and see how much end play you have over the length of the shaft(add or remove as needed). if you can get it down to .002 you will be good.
before I forget, if you find a bad bearing don't forget to replace it while your there
Yetti
Old January 27th, 2006, 12:21 PM   #8
Arnie897
y=mx+b
Arnie897's Avatar
Any special tools I may need to attempt this?
Old January 27th, 2006, 03:02 PM   #9
Yetti
Yetti's Avatar
not really, but if you have the front bearing support pulled and it falls apart in your hands then you have to able to fish out the parts and beable to put it back together. . if its a top loader trans then its very easy to repair, if its one piece body with a seperator plate and a tail shaft housing they are quite a bit harder to split to get at the insides. do you have a book or diagram that shows the break down of that trans? if yyou do it would certainly help
Yetti
Old January 27th, 2006, 04:35 PM   #10
Arnie897
y=mx+b
Arnie897's Avatar
I have my Chilton's....that won't help much with this though.
Old January 27th, 2006, 04:38 PM   #11
chris1044
chris1044's Avatar
What year sploder, and if you can what tranny?
Old January 27th, 2006, 04:50 PM   #12
Yetti
Yetti's Avatar
I have a book for a `90 model year if thats close enough, but I have no idea what year yours is
Yetti
Old January 27th, 2006, 05:08 PM   #13
Arnie897
y=mx+b
Arnie897's Avatar
This is a 97 Explorer with a 1993 Explorer tranny in it. It's the Mazda M5OD-R1 4x4 transmission.
Old January 27th, 2006, 07:12 PM   #14
nixxerRsixxer
Homewrecker
LOLZ!!! .. OMGZOR! .. its so getting worked on soon! someones been busy whoring himself out for $$
Old February 2nd, 2006, 09:31 PM   #15
Arnie897
y=mx+b
Arnie897's Avatar
Bought a NEW tranny. Updates after I take the old one out and play with it.
Old February 25th, 2006, 02:26 PM   #16
Arnie897
y=mx+b
Arnie897's Avatar
New tranny went in today. No more whine. What should I do with the core? Do junkyards buy this stuff? I can send it back to the place I got this new one but I'll only get $75 after shipping and all.
Old February 25th, 2006, 02:49 PM   #17
Yetti
Yetti's Avatar
see if you can ship it third class , then it maybe much cheaper and you get more money back.
Yetti
Old February 25th, 2006, 07:25 PM   #18
chris1044
chris1044's Avatar
hmmmmm.....4x4 tranny? Bolted to a 4.0 tranny? If so, I *may* be interested in it - I'm looking to do a manual swap in my ranger (I've got the POS A4LD right now). But I'm going to guess that a whole new tranny was cheaper than internals, even if you rebuilt it yourself right?
Old February 25th, 2006, 09:42 PM   #19
Arnie897
y=mx+b
Arnie897's Avatar
Yeah.....I would imagine so. This will bolt right up to a OHV 4.0 V6....and it is the 4x4 version. Let me know. It was driving when it came out....but it will need some work to make it "nice" again.
Page generated in 0.40516 seconds with 80 queries
