My frame rail broke on an xj is it weldable? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 21st, 2007, 10:17 AM   #1
disorder xj
Happy,happy,joy,joy
disorder xj's Avatar
Unhappy My frame rail broke on an xj is it weldable?
I have a 99 xj sport with about a 7 in lift and 33's .The frame rail on the driver side cracked right in front of where the sway bar mounts. behind the steering box . Can I weld this? Is it a sub frame that comes out? Or should I look for a new xj to put all my parts on
disorder xj is offline   Reply With Quote
Old March 21st, 2007, 10:19 AM   #2
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
never a bad idea to look for a new one once the frame goes but considering thats a unibody i dunno bout welding it.
nate4d is offline   Reply With Quote
Old March 21st, 2007, 10:19 AM   #3
BMFmike
meh.
BMFmike's Avatar
It is time for a sub frame.
Old March 21st, 2007, 10:30 AM   #4
thexjway
if you want a new xj i got one
thexjway is offline   Reply With Quote
Old March 21st, 2007, 10:56 AM   #5
Tweeternpi
Tweeternpi's Avatar
My wifes old MJ did that. We got a some steal,(about 1/4 inch. Bolted that thru that part of the frame and than welded it all the way around the steal we added. Never broke.
Tweeternpi is offline   Reply With Quote
Old March 21st, 2007, 10:57 AM   #6
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
Sorry, that is just funny.
I was going to say something along that as well.
*2007 Rubicon
*2006 Duramax
Old March 21st, 2007, 11:23 AM   #7
Blackjackbender
I am not suprised at all this happened
I would weld the crack back up. grind it smooth. then take 3/16" plate and weld it over the crack.
Then I would build/buy uni-body stiffiners.
Old March 21st, 2007, 11:38 AM   #8
disorder xj
Happy,happy,joy,joy
I'm going to try to weld it this weekend. I have to take the bumper off to see how bad it's really broke. it goes up under the braket to mount it.it looks like It's spider cracked under the braket.I don't really won't to switch everything . almost eveything is new motor ,trans, transfer case.
Old March 21st, 2007, 11:56 AM   #9
Toivo
Feel lucky?
Toivo's Avatar
completely plate around the unibody with thicker steel, 3/16 should work good, and fully weld the seams. make the steel over lap at least an inch, and for added piece of mind you could drill several holes in the steel before you weld it on to plug weld to the unibody rails. the better you plan, the stonger and better the weldments will be. you don't want to hack job the rail too bad, it is the only thing holding the front end of your jeep together, as well as the only thing that really provides adequate collison protection in the advent of an accident.
Old March 21st, 2007, 11:56 AM   #10
One Arm Steve
I was born in the desert
One Arm Steve's Avatar
Your looking on the wrong forum. Try looking here:
http://jeepspeed.net/smf/index.php?topic=418.0 (this link is acting up like G.L yesterday)
http://www.naxja.org/forum/showthread.php?t=903257
http://www.temper-mentalracing.net/services.htm
You can fix it if you have the right tools.
One Arm Steve is offline   Reply With Quote
Old March 21st, 2007, 12:07 PM   #11
One Arm Steve
http://jeepspeed.com/ these guys build em tough.
http://www.youtube.com/watch?v=4dU9M055RlU
Page generated in 0.27898 seconds with 56 queries
