'90 Chevy 2500 Diagnosing Code 32 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 21st, 2007, 07:44 AM   #1
drummond
MTU 4x4
drummond's Avatar
Default '90 Chevy 2500 Diagnosing Code 32
I have a 1990 Chevy 2500 with a 350, that I use as a tow rig. Lately, it has seemed to be burning quite a bit of fuel, so I am trying to figure out what may be causing it. I replaced the fuel filter, which was quite clogged, and I checked out the O2 sensor, and it defiantely had not been replaced in forever. Seeming as the cost for those isnt that much, I just replaced them. However, when I am driving around town, the engine rarely gets above 160*. I am wondering if this may be causing the engine to run in closed loop mode, (I believe that is the term) and dumping extra gas like the choke would be on. I have learned this could be from a bad coolant temp sensor, but I am not sure. Any ideas?
Also, when I am driving over speeds of 50-55 for a time period greater than 10 minutes or so, the check engine light comes on. I jumped the pins today, and I got a code reading of the standard 12 12 12 diagnosing mode then 32 which is a CODE "32 Exhaust Gas Recirculation (EGR) Circuit". I honestly have no idea what that is, or where I could find it, or what it could do. Any help would be awesome
drummond is offline   Reply With Quote
Old March 21st, 2007, 01:34 PM   #2
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
Your going to need an EGR valve. I had that happen on a '91 Suburban I had a while back. A new EGR valve cured the code. Clean out the carbon around the ports before you put it back together.
Old March 21st, 2007, 03:22 PM   #3
drummond
MTU 4x4
drummond's Avatar
is that going to help with the gas mileage at all? It seems to be burning more gas than necessary...
Old March 27th, 2007, 07:30 PM   #4
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
Gas milage not so mich. Idle quality and overall drivability won't be that great though.
Old March 30th, 2007, 12:13 AM   #5
ricdawg
ricdawg's Avatar
Sounds like you have two problems. The EGR valve which probably needs to be replaced and the engine temp. Youíre correct that the engine needs to be at full operating temperature (190 degrees +) for the computer to take control and lean out the fuel mixture. It could be something as simple as the engine thermostat itself or a coolant sensor. The coolant sensor for the gauge is a different sensor than the one for the computer. I would bring it up to operating temperature and then check the coolant temperature with a known good mechanical temperature gauge. If itís not around 190 degrees, replace the thermostat.
Rick
ricdawg is offline   Reply With Quote
Page generated in 0.33944 seconds with 38 queries
