Duals on a blazer - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 19th, 2007, 07:00 PM   #1
Searchin4acj
Got Sand???
Searchin4acj's Avatar
Send a message via AIM to Searchin4acj
Default Duals on a blazer
I just bought a set of headmen headers, should i put duals, or should i keep the factory y pipe set up and then go with single in dual out flowmaster muffler? i dont know what i should go with. i would like duals but nobody will touch it. what should i do.
Thanks nick
Searchin4acj is offline   Reply With Quote
Old March 19th, 2007, 07:19 PM   #2
StartingLine
StartingLine's Avatar
What engine do you have? TBI or carb. I personally like the sound and performance out of a single 3" on a TBI motor. And imo it sounds alot better. I'm not a big fan of the choppy true dual sound though. I have that single 3" on my TBI 305 truck, and my girlfriend's 350 Z71.
StartingLine is offline   Reply With Quote
Old March 19th, 2007, 07:27 PM   #3
Searchin4acj
Got Sand???
ya its 350 with tbi, i just bought the full tube headers so i would have to get a new y pipe then
Old March 19th, 2007, 07:28 PM   #4
Searchin4acj
Got Sand???
do you think i should just do a single in dual out?
Old March 19th, 2007, 07:57 PM   #5
backdraft
AKA Patrick just because
backdraft's Avatar
you can still go with true duals and put a h pipe on it but some ppl think it souds like shit but it depend on your own likeing
just a side note if you go with trues don't go much bigger then 2 1/2" to help keep the scavenging of the gasses up
backdraft is offline   Reply With Quote
Old March 19th, 2007, 08:03 PM   #6
Searchin4acj
Got Sand???
Default Duals
where can i get an h pipe ?
Old March 19th, 2007, 08:04 PM   #7
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
I would get a whistle tip. Sol Goode had one on his Yukon it sound and performed great.
Old March 19th, 2007, 08:08 PM   #8
chris1044
chris1044's Avatar
it's that wooo woooooooo
Old March 19th, 2007, 08:09 PM   #9
FQXehhhh
FQXehhhh's Avatar
i think true duals sound great with the chevy 350 motor. It just depends on how much time and money you want to spend. I have the single in dual out on my ford; it was easy to install and cheap. The sound quality isnt the best and id like to get a different set up once i get some spare cash
FQXehhhh is offline   Reply With Quote
Old March 19th, 2007, 08:14 PM   #10
chris1044
chris1044's Avatar
what do you want? Performance or sound??
Be cool like everyone, run true duals with 3" pipe all the way - because that motor definitely needs that
Old March 19th, 2007, 08:22 PM   #11
Freak
Wheelin the HD
Freak's Avatar
true duals, 3" pipe and glass packs Friend has it on his Monticarlo, Sounds great, and LOUD his 350 is punched over 60 and when your behind him and he steps on it your whole dashboard shakes, gets a lot of up for the exhaust.
Old March 21st, 2007, 09:56 AM   #12
Searchin4acj
Got Sand???
thanks for the imputs guys, big help
Old March 22nd, 2007, 05:33 PM   #13
bigblazer
ditch digger
I have 2.5 in to a single 3.5 and I really like the sound . Its not real loud though above 3000 rpms. I think it kinda chokes the motor out, or used to with the old cam. Duals will cost you more, with running 2 pipes. Do what you feel is right.
bigblazer is offline   Reply With Quote
Old March 25th, 2007, 01:02 PM   #14
love2wheel
tanto
ok ive had like 4 or 5 different exaushts on my s-10 it took me that long to find the setup that sounded good. if you plan on running single in dual out. you have to go bigger to smaller. such as 3" in - 2 1/2" out. by running single in dual out, your allowing a lot more to escape the muffler then what goes in. gasoline motors use backpressure from the exhaust to help run efficiently. if you want to run true duals i would go with 2.5" all the way back. and one last thing i ran flowmasters for the longest time. they start to get annoying. i switched to a magnaflow and will probably use a magnaflow for the rest of my life. just a thought!
love2wheel is offline   Reply With Quote
Old March 27th, 2007, 02:26 PM   #15
user name
keep your stick onthe ice
user name's Avatar
I read an article on single H-pipe and true duels on the same motor with tuning to them on a dyno. The single made more power than the other two from idle to near 4000. In my opinion a bigger single sounds a lot better to.
Page generated in 0.28826 seconds with 68 queries
