Axle Advice - Great Lakes 4x4. The largest offroad forum in the Midwest
View Poll Results: What to do with my rear axle?
Regear and Lock d35 1 3.45%
Swap in 8.8 28 96.55%
Voters: 29. You may not vote on this poll
Old March 19th, 2007, 08:58 AM   #1
Streaver
Streaver's Avatar
Send a message via AIM to Streaver
Default Axle Advice
I currently have an open d35 at 3.07 in my 95 yj. Should I bother regearing and locking it, or just skip that and look at a 8.8 swap?
Streaver is offline   Reply With Quote
Old March 19th, 2007, 09:21 AM   #2
mlfreund@mtu.edu
Traverse Mi
mlfreund@mtu.edu's Avatar
I have a scout dana 44 setup for a YJ Spring under w/ 3.56 gears minus brakes for $125 PM if interested
mlfreund@mtu.edu is offline   Reply With Quote
Old March 19th, 2007, 09:54 AM   #3
greenmeanie
greenmeanie's Avatar
don't bother w/ the 35; you may want to make the jeep big someday, and you'll need a better axle then. if you for some strange reason keep the 35, i have the carrier you need to put 4.10's and lower in it and also have some new brakes for it; but do the 8.8....
greenmeanie is offline   Reply With Quote
Old March 19th, 2007, 10:28 AM   #4
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
You never mentioned how big your tires are, what other potential driveline changes you have (e.g. - more powerful motor), how you use your Jeep, etc. That would help suggestions from folks.
Craig
Old March 19th, 2007, 10:30 AM   #5
Streaver
Streaver's Avatar
4.0L, with 33's. It's my dd. Not planning on getting any bigger for a while.
Old March 19th, 2007, 11:30 AM   #6
Square-D
Administrator
Square-D's Avatar
There are two types of dana 35 axles. Those that have broke, and those that will.
8.8
Square-D is offline   Reply With Quote
Old March 19th, 2007, 11:34 AM   #7
MozMan68
Poseur Extraordinaire
MozMan68's Avatar
you WILL go bigger...trust me...
MozMan68 is offline   Reply With Quote
Old March 19th, 2007, 11:46 AM   #8
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
8.8 is fairly easy swap....just do that and don't waste money on d35.
find a 8.8 w/4.10's...then find 4cyl yj d30 with 4.10 gears and swap that into the front.
Old March 28th, 2007, 03:51 PM   #9
Mongo
Mongo's Avatar
X2
Plus you get extra front shafts, yoke and such.
Doing all of the work myself, total cost was around $500 for everything.
Mongo is offline   Reply With Quote
Old March 28th, 2007, 09:45 PM   #10
redmud
10 0011 10101
redmud's Avatar
I'd go with the 4cyl front axle, but put an Isuzu/Honda D44 in the rear, They are easy to find under Passports and Rodeos, and a little wider than the 8.8, nearly as strong and have better ground clearance, disc brakes, and is just as cheap at the local U-pull it. The only downside may be the 6 on 5.5 bolt pattern. Actually the new JP came today and they did a decent write up about it. That's what I'm ultimately putting under my TJ.
redmud is offline   Reply With Quote
Old April 4th, 2007, 09:40 PM   #11
95geo
newbie
95geo's Avatar
if you dont go right to 2.5 ton rockwells then your wasting your time... youll be there eventually so why not now?
Old April 4th, 2007, 09:43 PM   #12
steveo
In the band!
x2
Page generated in 0.40523 seconds with 60 queries
