dual cases - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 18th, 2007, 06:47 PM   #1
88yj
collecting parts
88yj's Avatar
Send a message via AIM to 88yj
Default dual cases
Who all is running dual cases? What size tires and what gearing in each case?
I'm running 35s and trying to decide if I want 2.8/2.8 or 2.8/4.0 for a combo. The 2.8/4.0 seems more versatile, but I'm not sure I'd ever need 2.8x4.0 low range around here. I do plan to travel around and hit more rocks, but I'll probably spend most of my time trail riding. Thanks.
88yj is offline   Reply With Quote
Old March 18th, 2007, 08:21 PM   #2
Its 2.28, not 2.8.
I run Duals with 36" swamper SXs, 2.28 in each case, 4.88 axle gears, 22RE, and L52 5 speed trans. 100:1 overall.
I don't see a need for what I've run for lower gears in the rear case. There were a few spots in Tellico it'd have been nice, but I wasn't exactly hurting for gearing. My engine doesn't idle as good as it should, either.
I'd start with the duals, then go from there.
Consider if you want a clocked case, too. I wish the adapters would have been out when I got my doubler, I would have clocked the rear case upwards.
Next truck will get a single case with 4.0 gears, if I can still find them.
Old March 18th, 2007, 09:23 PM   #3
88yj
collecting parts
88yj's Avatar
I actually knew that. I'm running on zero sleep and left out the 2 in 2.28.
My plan was to keep the gearing as is this season and possibly upgrade next winter. Case won't be clocked for now, but I'm not about to tear down the trans/case/case assembly to clock it right now. Again, something to consider over the winter.
Thanks for the reply.
Old April 15th, 2007, 02:55 PM   #4
heintzm756
I ran duals in my oil truck, stock cases, 5.29s and 38's. it was a nice set up
heintzm756 is offline   Reply With Quote
Page generated in 0.15917 seconds with 35 queries
