where can i get parts for my detroit truetrac - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 18th, 2007, 10:42 AM   #1
busyfixin
Balls Deep
busyfixin's Avatar
Default where can i get parts for my detroit truetrac
i am in need of one drive gear, and two helical gears for my D44 truetrac. mine are stripped all to crap where can i order these parts from? i need them ASAP!!!
Old March 18th, 2007, 10:49 AM   #2
mudd_jumper
mudd_jumper's Avatar
I have had good luck from 4WD parts I am sure there are others also out there
Old March 18th, 2007, 10:53 AM   #3
84Chevy
I'm Really Hurf
84Chevy's Avatar
Located in Detroit
http://www.drivetrainspecialists.com/
84Chevy is offline   Reply With Quote
Old March 18th, 2007, 11:33 AM   #4
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
To be honest it may cost you a small fortune to fix. The last one I repaired it took 6 weeks to get the internals and was over $250. Come to think of it PM h8pvmnt, he has a high series true trac that you can gut and use, Or if you have a 3.92 or higher gear just use the whole carrier. It has only 4 runs on it since I built the axle 2 years ago. He went to a full detroit, it is in great condition.
Old March 18th, 2007, 09:09 PM   #5
h8pvmnt
Swamp Stomper
h8pvmnt's Avatar
Yes I have a complete unit I just posted for $200 o.b.o.
h8pvmnt is offline   Reply With Quote
Old March 21st, 2007, 03:08 AM   #6
busyfixin
Balls Deep
busyfixin's Avatar
sounds like its time for the squarewave to go to work. i dont want a limited slip that bad. "seviceless" differential my ass, im pretty sure mine needs servicing. i cant even find a customer service number on their site. ill buy a spool next time.
Page generated in 0.13991 seconds with 41 queries
