Wheel bearings on my 1999 Yukon - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 15th, 2007, 01:06 PM   #1
Mr.Green
I can levitate!
Mr.Green's Avatar
Default Wheel bearings on my 1999 Yukon
Can the wheel bearings be replaced or do you have to replace the entire hub?
Old March 15th, 2007, 01:08 PM   #2
n8big
Size Matters
n8big's Avatar
Send a message via Yahoo to n8big
You have to replace the entire HUB UNIT!!!!
n8big is offline   Reply With Quote
Old March 15th, 2007, 01:16 PM   #3
Mr.Green
I can levitate!
Mr.Green's Avatar
Sounds better than bearings and races.
Old March 15th, 2007, 02:37 PM   #4
badazzamc
Get Some
badazzamc's Avatar
not when you see the price.
Old March 15th, 2007, 02:42 PM   #5
Mr.Green
I can levitate!
Mr.Green's Avatar
Yup, I figured that is the case. Thats the price to drive a PIMP vehicle like this though. She is a beauty!!
Old March 30th, 2007, 12:03 AM   #6
ricdawg
ricdawg's Avatar
With a lot of f'ing around you can replaced just the sealed bearings in the hub. Most auto parts stores will tell you the bearings are not available separate but you should be able to get them through an industrial bearing supplier. You will also need a hydraulic shop press and some ingenuity. Much easier to just replace the entire hub unit.
ricdawg is offline   Reply With Quote
Old March 30th, 2007, 12:16 AM   #7
boggin-machine
boggin-machine's Avatar
247 a bearing at my cost for my 2000 gmc k2500
Old March 30th, 2007, 03:41 AM   #8
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
make sure to price out napa and the other part stores.. when i replaced the unit bearings in my dodge they were a lifetime warranty..
nixxerRsixxer is offline   Reply With Quote
Old March 30th, 2007, 06:44 AM   #9
GetItOffroadGMC
GetItOffroadGMC's Avatar
Lil trick for those. Im sure Green has his fixed by now but on mine I replaced with a pre abs year and saved quite a bit. I dont like ABS anyways. Mines a 98 K2500 and I used a 92 K2500 bearing.
GetItOffroadGMC is offline   Reply With Quote
Old March 30th, 2007, 07:01 AM   #10
max5p33d
slack jawed faggot
max5p33d's Avatar
Send a message via ICQ to max5p33d Send a message via AIM to max5p33d Send a message via Yahoo to max5p33d
Bummer, i just sold a pair of these on ebay for 175. OEM New...
max5p33d is offline   Reply With Quote
Page generated in 0.23150 seconds with 53 queries
