98 z-71 wont start - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 14th, 2007, 07:35 PM   #1
coyne
coyne's Avatar
Default 98 z-71 wont start
fuel pressure 54 lbs ....last time it did start weeks ago ran for 10 minutes then shut off wouldnt restart.........any ideas pm please thanks in advance troy
coyne is offline   Reply With Quote
Old March 16th, 2007, 10:30 PM   #2
gmcpower98
Geocacher!!!!!!!!!!
gmcpower98's Avatar
Try to reset the computer.
1. turn key to run (last click before turning starter).
2. let it set in run position for 20 minutes (no longer, no shorter. use a timer).
3. turn key to off position.
4. start engine.
I have had the won't start problem on and off for years.
A service tech. told me to try this.
Works for me!!
I mostly have this problem 1 or 2 times a year.
Mostly when it has been wet or heavy dew in A.M..
Let me know if this works for you. Good luck!!
gmcpower98 is offline   Reply With Quote
Old March 27th, 2007, 07:18 PM   #3
user name
keep your stick onthe ice
user name's Avatar
key on engine off thats bellow spec if im not mistaken spec is 61-66psi. If it has the poppets like I'm thinking it will not even think about running with any less pressure.
Old March 27th, 2007, 08:50 PM   #4
djlipp
998,999,1000
djlipp's Avatar
Yep, 54psi is not enough for a vortec 5.7
djlipp is offline   Reply With Quote
Old March 28th, 2007, 12:39 PM   #5
shredder70
Chillin with the top off.
shredder70's Avatar
try a shot of carb clean in the throttle body, if it fires you know you have a fuel delievery problem..
shredder70 is offline   Reply With Quote
Old March 29th, 2007, 08:53 PM   #6
Trail-XJ
Bank Account Understands!
Trail-XJ's Avatar
check how many amps the fuel pump is drawing......high= tired pump
Trail-XJ is offline   Reply With Quote
Old March 30th, 2007, 01:28 PM   #7
user name
user name's Avatar
It may also be a good idea to put in a new fuel pump relay i was told they tend to lead to fuel pump burn out from excessive voltage drop across them and they only cost like $10.
Page generated in 0.31820 seconds with 44 queries
