93 Sploder Mpg Gains - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 14th, 2007, 06:12 AM   #1
Shotgun
I only wheel with boats.
Shotgun's Avatar
Default 93 Sploder Mpg Gains
Does any one know why my sploder would get about 5 mpg better when the temp is above 45. I was averaging 15 or so during the cold spell now with 60's upon us I am getting 20 or so.
Old March 15th, 2007, 02:35 PM   #2
Drg racr
Drg racr's Avatar
Yours is good compared to mine, I get a best of 13 in the winter. I hear most Explorers get worse mileage in the winter. Maybe they're just warm blooded creatures! ;)
I get a best of 18 in the summer, mine's a '94.
Drg racr is offline   Reply With Quote
Old March 15th, 2007, 08:12 PM   #3
Shotgun
Shotgun's Avatar
the difference is mine is 2wd :-( and a 5sp,
Old March 15th, 2007, 09:33 PM   #4
chris1044
chris1044's Avatar
I think the key to good gas mileage is proper gearing with the 4.0
A lot of the rangers/sploders came from the factory with 3.27's in them, way to tall of a ratio IMO for something as heavy as an explorer. The 5 speed transmissions are ten fold better than the a4ld in both strenght and power transfer, but honestly my 4.0 had a huge mileage gain when I put in my gears with the tires - I'm running 4.56's with 33's, and pull roughly 19-22 on the highway going right around 68 mph....and that's with it lifted. When it was stock, I was lucky to get that on the highway.
But, even if they do get shitty mileage, if you've got the 4.0 your set - that motor is a damn reliable work horse (well, the OHV ones.....the SOHC have more than a few problems)
Old March 15th, 2007, 10:34 PM   #5
yeah lets blaze has the open 3.27 8.8
Old March 16th, 2007, 12:33 PM   #6
chris1044
chris1044's Avatar
Yep, thats what I assumed - when my truck had that gearing, even with small 235's on it the motor would barely turn 1900 rpm at 75.....which isn't even near the torque peak of that motor....
Old March 16th, 2007, 08:28 PM   #7
Shotgun
Shotgun's Avatar
I run about 2500 at 75 or so. damn nowonder I chug fuel
Old March 16th, 2007, 08:31 PM   #8
Shotgun
Shotgun's Avatar
I thought I was running 373's
Old March 16th, 2007, 09:47 PM   #9
chris1044
chris1044's Avatar
Actually, 2300-2500 is ideal with the OHV 4.0 at that speed (or what ever speed you choose is the optimum highway speed for you). There's a big misconception that you'll get worse fuel mileage as RPM's increase - and that's true to a point. But, in my experience, my truck seems to get better mileage around 2300-2500 rpm....just before the engines torque peek.
If you're still getting poor mileage, I'd start looking for something that could cause it (engine running rich for some reason - skewed ECT, bad O2, etc....)
Old March 16th, 2007, 11:25 PM   #10
Shotgun
Shotgun's Avatar
the ecu reads fine, no check engine lights on. I dunno
Old March 27th, 2007, 07:59 AM   #11
Drg racr
Drg racr's Avatar
I run 3.73's in mine, with a rear limited slip. I did find out a problem, though. the past week or so, the torque conv. is coming out of lockup. Also, the check enging light is on, and throws a code showing the Air Charge Temp sensor is out of specs. These are probably the culprits.
Page generated in 0.49709 seconds with 56 queries
