91 Geo tracker fuel pressure? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 12th, 2007, 08:18 PM   #1
Gr8wht2000GMC
Gr8wht2000GMC's Avatar
Default 91 Geo tracker fuel pressure?
how much fuel pressure is req'd for a 91 with a 1.6L? Could I run this engine on a frame mounted elec. pump? its a tbi system so I think I may be able to do this?!
Gr8wht2000GMC is offline   Reply With Quote
Old March 13th, 2007, 08:40 AM   #2
swampjeep
Swamp Stomper
swampjeep's Avatar
I'm not sure on this, but most TBI's are between 9-14 psi
swampjeep is online now   Reply With Quote
Old March 13th, 2007, 12:05 PM   #3
jimmyroyse
webwheeler
jimmyroyse's Avatar
carbs are between 5-7 psi
efi / tbi are 30-40 psi
I'm running an in-line pump for a mid 80's ford 302
jimmyroyse is offline   Reply With Quote
Old March 15th, 2007, 05:14 PM   #4
95geo
newbie
95geo's Avatar
FUEL SYSTEM PRESSURE SPECIFICATIONS
Engine Idling 240-280 kPa (34-41 psi)
Key ON engine OFF 240-280 kPa (34-41 psi)
Key ON engine ON 172 kPa (25 psi)
you need an in tank pump that came with the truck
Old March 15th, 2007, 07:12 PM   #5
Gr8wht2000GMC
thanks 95geo, its just so rusted up and rigged to drive that i hoped to cheat once more! Altho the pump will be fairly easy to access because the floor in back is plywood and fibergass, Ill just cut me a hole in the floor!
Old March 16th, 2007, 09:47 PM   #6
hman1991
hman1991's Avatar
Send a message via AIM to hman1991
if it is just a beater you can use any in tank fuelpump that looks close. i ran a civic pump in a toyota pickup. they don't fit in sending unit perfect but a couple zipties u r good to go. so if you cannnot find a tracker 1 start lookin for civic. there is usually a ton in the junkyard. also tracker fumps r known to fail. i have 2 spares for my samurai. and have replaced 1 in my old tracker.
hman1991 is offline   Reply With Quote
Old March 16th, 2007, 10:02 PM   #7
Gr8wht2000GMC
Default its a beater alright !
yea its a beater. I bought it for my wife and she drove the piss outa it for a couple years. then the back seat brackets rusted off (along with the rest of the rear floor) so I inttalled a treated wood floor and sealed the edges with fiberglass. then when gas hit me hard in my 454 I started to drive it. now the pump is out and i hate to try to drop the tank. but i want the 28 mpg!!
Old March 17th, 2007, 12:28 PM   #8
hman1991
hman1991's Avatar
just cut a hole in the floor. i u r not sure were it is at i can take a pic of top of tank. but it was just 4 bolts to drop it. but when i did my fuel tank i cut it open and peeled it up but with doin that you have to cut into your door seal since the tank is so far back.
Old March 18th, 2007, 09:00 AM   #9
Gr8wht2000GMC
i engineered some boby lift into this POS a couple years ago. I can see the top of the tank pretty clearly. Thanx for the offer tho!
Page generated in 0.24111 seconds with 50 queries
