trashing cams - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 12th, 2007, 09:29 AM   #1
91 k1500
Big Belly Customs
91 k1500's Avatar
Send a message via AIM to 91 k1500
Default trashing cams
I have a 350 small block in my 91 k1500. problem is, I keep wiping cam lobes off! first time it did it on #8 exhaust side, this time it did it on #1 exhaust side. anyone know why it keeps doing this? it is a 2bolt block with 5.7 rods, foraged flat tops, vortec heads with springs set up for 500 lift, comp cams lifters and cam, it is a .490 lift on int and exh, roller rockers, edlebrock intake 650 holley dp carb and an msd hei at 32 total timing. cam and lifters where brand new not even 100 miles ago! gonna go roller now, but I want to make sure I am not gonna have this happen again. really getting expensive replacing cams all the time!
91 k1500 is offline   Reply With Quote
Old March 12th, 2007, 09:34 AM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Did you get all the metal cleaned out from the first time it wiped the cam?
Old March 12th, 2007, 11:25 AM   #3
91 k1500
Big Belly Customs
91 k1500's Avatar
Yeah, I flushed oil trough it three times, and I installed new cam bearings.
Old March 12th, 2007, 12:57 PM   #4
frdboy
frdboy's Avatar
How are breaking-in the cam, and what oil are you running?
Old March 12th, 2007, 01:25 PM   #5
chris1044
chris1044's Avatar
X2 - a new cam must be broken in properly, and if you were running flat tappet lifters its not supposed to idle during break in IIRC
Old March 12th, 2007, 01:32 PM   #6
frdboy
frdboy's Avatar
Correct, also you should run a diesel oil (shell rottella, mobil delvac) or run an additive to reg. oil, such as gm's EOA at least during the first 500 miles.
Have you checked for coil bind, and that the rockers are not hitting at full lift?
Adam
Old March 12th, 2007, 03:00 PM   #7
91 k1500
Big Belly Customs
91 k1500's Avatar
I am firing the engine and running at 2000rpm for 30min, using murreys oil for break in, then switching over to valvalene 10-30 synthetic. running comp cams 982 spring kit that makes it so you can run .500 lift without machining vortec heads.
Old March 12th, 2007, 03:10 PM   #8
chris1044
chris1044's Avatar
Personally, I'd assemble everything with a good engine oil assembly lube, and run a heavy weight straight dino oil for break in, and continue on with the dino oil for atleast 5k....synthetic isn't good to break a motor in, and after a mear 30 mins those parts aren't truelly done wearing on each other for the long haul.
But also as stated, make sure the rockers aren't hitting or bottoming the lifters (assuming hydraulic) out at full lift, and make 100% sure there isn't any coil bind. .5" is quite a bit of lift - what are your intentions for the motor??
Old March 12th, 2007, 03:22 PM   #9
djlipp
998,999,1000
djlipp's Avatar
You say the heads are set up for 500 lift but do the springs bind before 500 lift?? I've seen this same senario with vortec heads and bigger cam.
Btw if this is a comp cam they are soft and shitty to begin with..
djlipp is offline   Reply With Quote
Old March 12th, 2007, 03:24 PM   #10
frdboy
frdboy's Avatar
Have you checked yourself for coil bind? Do you know what your installed height is on YOUR springs. Also make sure the lifters spin freely in there bores. Two cams having issues I would look at everything closely
You still need to run a oil with Zinc in it (ie. rotella) to help with break-in.
I also would run a dino oil for 1000 miles.
Old March 12th, 2007, 03:25 PM   #11
frdboy
frdboy's Avatar
I don't agree with this, I have installed a ton of their cams without issue.
Adam
Old March 12th, 2007, 03:40 PM   #12
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
I don't agree with this, I have installed a ton of there cams without issue.
Adam
I agree 100% I have run many comp cams. My guess is that you are breaking the cam in wrong or you don't have the valves adjusted properly.
Old March 14th, 2007, 10:28 PM   #13
user name
keep your stick onthe ice
user name's Avatar
the reason is quite possibly your oil with a flat tappet cam you should be running an oil with phosforus(sp?, I think thats the one) most oils today have dropped it because the roller lifters dont need the pressure adative it provides. rotela is the only oil i know for sure that still has it but most of the diesel oils probly do.
Old March 14th, 2007, 10:45 PM   #14
KILLER"B"468
Yankabilly
I think it is zink you are talking about..
Old March 14th, 2007, 10:55 PM   #15
71jeepster
Glad I'm not Gay J. Hall!
71jeepster's Avatar
Send a message via Yahoo to 71jeepster
i've got a gallon of this at home, is it ok to run in gasoline engines or no? i haven't used it because i was unsure if it was ok to use. sorry for the hijack, but if i can't use it someone can have it if they want it.
71jeepster is offline   Reply With Quote
Old March 15th, 2007, 07:43 AM   #16
91 k1500
Big Belly Customs
91 k1500's Avatar
I posted this question on two other forums and all have came up with the same thing. So I am gonna see if I can get comp to cover the cam and I am gonna break the new one in with rotela and see if it will hold up this time. Thanks for all the reply s, and I will keep ya informed on what happens.
Old March 15th, 2007, 07:52 AM   #17
max5p33d
slack jawed faggot
max5p33d's Avatar
Send a message via ICQ to max5p33d Send a message via AIM to max5p33d Send a message via Yahoo to max5p33d
Did you prime the engine before you fired it?
max5p33d is offline   Reply With Quote
Page generated in 1.17198 seconds with 74 queries
