97 chevy 5.7 L - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 11th, 2007, 09:16 PM   #1
Grandman
do i look old !
Grandman's Avatar
Default 97 chevy 5.7 L
Just bought this truck a bit a go . Runs great , mileage is way below what it should be . 8.6 mpg pulling the Grand . Iv owned Silverados like this before and they all did 11 to 13 mpg towing .
It had a code for o2 sensor when i bought it . wiped out the code to see if it came back on but it has not .
question , will a bad o2 sensor kill fuel mileage ?
Same 3:73 Gears as the other had , New tires 45 psi .
New air filter , plugs are good blah blah . What else may be killing its economy ?
Old March 11th, 2007, 09:28 PM   #2
scottie
Eye candy
scottie's Avatar
yes a bad O2 sensor will kill fuel mileage. and about every other emission thing will kill fuel mileage. Sometimes a Fuel pump that is on the outs can cause it too. Lots of things can kill it
what does it get not towing?
Old March 11th, 2007, 10:08 PM   #3
Grandman
do i look old !
Grandman's Avatar
I hae not checked it on a truck only run yet .
Old March 11th, 2007, 10:18 PM   #4
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
I know when my O2 went on the blazer, it dropped 3-4 MPG's.
Old March 12th, 2007, 01:51 PM   #5
Grandman
do i look old !
Grandman's Avatar
Spoke to a local shop today about plugging it in . Said to change the fuel filter first . Said it is common for them to plug up and go lean then the pc will compensate and get bad economy .
Filter was indeed pretty plugged . Ill see where it goes from here .
Thanks for the ideas guys .
Old March 12th, 2007, 01:52 PM   #6
Grandman
do i look old !
Grandman's Avatar
Thats what i figure im off by , 3 to 4 miles to the gallon compared to the other identical silverados i have owned .
Old March 12th, 2007, 06:30 PM   #7
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
sounds like your on the right track. I would put it in the air and check everything. the idea is make sure you eliminate anything that could drag a brake or cause undue load. I have even seen busted engine mounts cock an engine and the load on the driveline was enough to drop a couple miles off. have you checked the parking brake and stuff yet?
Yetti
Old March 12th, 2007, 06:36 PM   #8
Grandman
do i look old !
Grandman's Avatar
Ya it had new rear brakes just before i bought it . Took care of that issue as they had the self adjuster screwed up and it would over tighten the D side rear brake . That was an early find
being i just bought it iv been going over and under it often . Ill see where im at now . If its still low ill take it in for a scan .
Old March 16th, 2007, 11:35 PM   #9
gmcpower98
Geocacher!!!!!!!!!!
gmcpower98's Avatar
Catalitic converter plugged up?
gmcpower98 is offline   Reply With Quote
Old March 17th, 2007, 05:11 PM   #10
farm_boy
hicktown
farm_boy's Avatar
when i put the new muffler on my 94 gas milage when up but had blak smoke 2 mpg turns out i needed a fuel fiter and a new o2 sener
farm_boy is offline   Reply With Quote
Old March 18th, 2007, 10:19 AM   #11
Grandman
do i look old !
Grandman's Avatar
Ran 15.2 on a trip yesterday 60 and 70 mph run , most of it 60 on a 2 lane so its still down from what i think it should get . Fuel filter helped .
This truck should run 16.5 to 18 on that type of run i think .
Old March 18th, 2007, 01:32 PM   #12
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
it should, maybe the higher mileage of the motor has something do with it?
At best I can only get 16.5mpg out of my '99 Suburban w/5.7L(112k) and 3.73 gears. I have 265/75/16 tires.
But the 'Burban is carrying about 800-1000lbs more body weight than your Pickup.
Old March 18th, 2007, 02:06 PM   #13
StartingLine
StartingLine's Avatar
Do you know what your compression is?
StartingLine is offline   Reply With Quote
Old March 19th, 2007, 01:23 PM   #14
Grandman
do i look old !
Grandman's Avatar
I have not put a gage on it but it starts and runs strong , no oil consumption . No reason to think the motor has any internal issues .
Page generated in 0.36203 seconds with 65 queries
