whats the hell is this - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 10th, 2007, 08:43 PM   #1
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
Default whats the hell is this
im looking at my brother and laws 78 ford pick up 3/4 ton 4wd, on the front axle there is a steering stabilizer almost but with 2 lines going to it. what is it i know it leaks like a bitch. id guess it has to do with the power steering seeings that it has the p/s lines going to it. let me know i need one.thanks
Old March 10th, 2007, 08:45 PM   #2
caveman
GeoDude
caveman's Avatar
sounds like a factory hydrolyic (sp?) steering ram. i've heard thier junk.
Old March 10th, 2007, 08:46 PM   #3
caveman
GeoDude
caveman's Avatar
if you want to fix it i've also heard parts a way spendy for as good as they work
Old March 10th, 2007, 08:47 PM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
thats a power control valve assemblly. if you had the older one it has the sensor valve seperate in the middle of the drag link. their a bitch to repair. if you can find a rebuild unit and install it, if you've never repaired one don't try.
Yetti
Old March 10th, 2007, 08:51 PM   #5
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
External cylinder, linkage type steering.
<edit> beat me to it Yetti.
On the right.
Old March 10th, 2007, 08:52 PM   #6
caveman
GeoDude
caveman's Avatar
like i said, its a power control valve assemblly, External cylinder, linkage type steering.
Old March 10th, 2007, 09:08 PM   #7
unclebeaner
were can i get one and can you just bypass it by looping the lines
Old March 10th, 2007, 09:28 PM   #8
unclebeaner
anybody?
Old March 10th, 2007, 10:12 PM   #9
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
If you bypass it, you will have no power steering. It will be all armstrong steering.
Old March 10th, 2007, 10:26 PM   #10
72cj304
72cj304's Avatar
try prickanddicks.com I had to get one for a 77 I had that or try lmctruck.com good luck they are hard to find it may be prickanddicks4x4.com
72cj304 is offline   Reply With Quote
Old March 11th, 2007, 10:26 AM   #11
unclebeaner
these bastards are hard to find do any one had one of these sitting around?
Old March 11th, 2007, 11:46 AM   #12
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Yes they are hard to find. I only have one and can't let it go because I use it to teach with.
You might want to look into converting it to a regular saginaw box.
Old March 11th, 2007, 11:47 AM   #13
unclebeaner
most likely hard to do?
Old March 11th, 2007, 12:16 PM   #14
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I think it may be easier and cheaper then finding parts for the one you have.
Old March 11th, 2007, 12:30 PM   #15
unclebeaner
do you have to get a new steering shaft and pitman arm, drill the frame ect.?
Old March 11th, 2007, 12:34 PM   #16
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
In 78, the 3/4 ton extended cab had the option for the Integral Gear style steering box. Might be a bolt in project.
The steering gear is 300 bucks at NAPA though.
Old March 11th, 2007, 05:09 PM   #17
unclebeaner
nope there is alot of work needed to do this.
Old March 11th, 2007, 06:06 PM   #18
Yetti
Yetti's Avatar
just to clue you in on prices. the sensor valve alone is around $700. so if you can afford that then I would convert to a newer system. loads less problems too.
Yetti
Old March 11th, 2007, 07:10 PM   #19
unclebeaner
250 on lmc truck .com
http://lmctruck.com/icatalog/fc/0095.asp
Old March 11th, 2007, 07:20 PM   #20
unclebeaner
http://www.ford-trucks.com/article/i..._F250_4x4.html
pretty involved just trying to help him out while im in st.louis
Page generated in 0.25359 seconds with 83 queries
