Axle rebuilt steps.... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 9th, 2007, 06:59 AM   #1
Camo-5
And yet another Heap.....
Camo-5's Avatar
Default Axle rebuilt steps....
I picked up a project N/T D30 to rebuild in my spare time (yeah, right). Anyway, here is what I want to accomplish:
1) install 4.56 gears (I'm planning on letting Killer B do this since I don't have a clue)
2) install a locker (probably Aussie, I'll let KB do this also)
2.5) install new bearings, etc.
3) rebuild / replace all the brake components (disc)
4) sand blast and powdercoat or POR15 the axle
Here is my question: Should I have the axle blasted / coated before I have the guts changed? Do I need to clean the inside of the housing before I blast / paint? Does it matter? Sorry for the stupid question, but it seems I do everything backwards these days and cause myself more grief (and $$). Thanks.
Camo-5 is offline   Reply With Quote
Old March 9th, 2007, 09:18 AM   #2
sodapop
Support the Sport!
sodapop's Avatar
First, do not powdercoat it. As soon as the coating gets a decent scratch, it will start to flake. Pick a nice strong paint like POR15 or rust bullet of on the cheaper end, TSC tractor paint with a hardener in it.
Second. I wouldn't blast the inside of the housing. Clean that up with brake cleaner and then cover it if you are going to sandblast it. I would do any sandblasting before I installed any new pieces, then clean it crazy good before reassembly. I just wire wheel the snot out of mine rather than having it blasted and it came out pretty good. I still haven't painted it though because I need to set the perches first but I'm planning on use TSC tractor paint.
Page generated in 0.13631 seconds with 29 queries
