T-case Drop - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 7th, 2005, 06:47 PM   #1
Saharaboy
Donate to Me
Saharaboy's Avatar
Send a message via AIM to Saharaboy
Question T-case Drop
When to do a drop?
I have been told both 2" and 3" as the breaking point for a drop of the t-case. I am at 2.5" and seem to think I have some drive line vibes? Should I drop it like 3/4 of an inch just to see if it helps? Also a drop jsut includes spacers to the frame and longer bolts right?
Saharaboy is offline   Reply With Quote
Old November 7th, 2005, 07:00 PM   #2
ogerdgonz
ogerdgonz's Avatar
Yes all a drop involves is spacers for the skidplate to be lowered away from the frame rail. I know you are busy but before doing the drop you could always measure the driveshft angles at the case and axles on yours versus a stock one. You could then copy the angles onto graph paper and do the work of moving the top part of the triangle down 3/4 of an inch and draw the new lines, measure the angle and see if their is really any gains.
BTW Tell Kelly and Bill this site looks great. I really like the lack of ads on the side!!!!!!!
ogerdgonz is offline   Reply With Quote
Old November 7th, 2005, 07:11 PM   #3
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
Drop kit is just spacers and longer bolts..
I have an RE 3.5" with .75" spacer up front (about 5" of lift net).. I also have a 1" MML + 1.25" BL and my t-case is not dropped.. (No SYE or CV DS) this is with a 4.0 5spd and Dana 35..
I have some vibes on hard acceleration.. but it still drives better than any other lifted Jeep .. lift has been on for about 2 years and has seen action in wellsville/yellow creek w/ 35 tires .. u-joints still seem to be fine in the d-shaft..
nixxerRsixxer is offline   Reply With Quote
Old November 7th, 2005, 07:15 PM   #4
Saharaboy
Donate to Me
Saharaboy's Avatar
Ya my u-joints are fine, I just know that something is causing some small vibes, nothing I haven't driven with for awhile now anyways, but was just thinking this might help it out. But who knows, I am sure I have a dozen other issues also
Old November 7th, 2005, 07:18 PM   #5
Jeeptj1999
Jeeptj1999's Avatar
On a tj 3.5" is about the limit in my opinion.
Jeeptj1999 is offline   Reply With Quote
Old November 7th, 2005, 08:59 PM   #6
Depends on the application/configuration of the TJ. Different transmissions are different lengths. The Dana 44 has a longer snout than the Dana 35, etc..
My on 98 TJ had one of the shortest possible, with the 5 speed and the Dana 44, I think 11-12" between the U-joint caps.. I needed a 1" drop with my RE 3" lift...
Old November 7th, 2005, 10:36 PM   #7
Tonka
Tonka's Avatar
I'll stop by with the angle finder one day.
takes a few minutes to fugure out how far off the angles are
Old November 8th, 2005, 08:14 AM   #8
Saharaboy
Donate to Me
Saharaboy's Avatar
Thanks Eric
Old November 8th, 2005, 09:04 AM   #9
JeepRat
Infidel
JeepRat's Avatar
I have a 1" t-case drop kit for a TJ if you want to try it out. Come pick it up.
JeepRat is offline   Reply With Quote
Old November 8th, 2005, 03:00 PM   #10
C.K.
Dont Feed the Cyco
C.K.'s Avatar
Thats about right. My first lift was about 3.5" to 4" and thats when I dropped the t-case. I did pull the spacers after a while and ran it in the stock location. It wasnt too bad but not really advised. With 2.5" you should be fine in the stock location.
C.K. is offline   Reply With Quote
Old November 8th, 2005, 03:19 PM   #11
Saharaboy
Donate to Me
Saharaboy's Avatar
Ok so any other ideas where I am getting driveline vibes??
Old November 8th, 2005, 03:30 PM   #12
nixxerRsixxer
Homewrecker
worn u-joint front d-shaft..
Old November 8th, 2005, 09:52 PM   #13
C.K.
Dont Feed the Cyco
C.K.'s Avatar
I couldnt find where mine were coming from until I pulled the front shaft. All gone. Now I just strap it up when I go on long drives and keep it hooked up to the t-case.
Old November 9th, 2005, 05:23 PM   #14
biohazardbill
Guest
Posts: n/a
Dont drop the tcase... do a motor mount lift instead...
Old November 9th, 2005, 05:29 PM   #15
Tonka
Tonka's Avatar
agree, but worst case we can drop the t-case super cheap. he may only need 1/4"
Old November 9th, 2005, 08:02 PM   #16
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Really depends on how tolerant you are of vibes. An angle vibe will really only show itself at a certain speed... or a few speeds.
if you have a vibe that shows up at a speed, and just keeps getting worse the faster you go, your looking at a bad u-joint, centering ball, or unbalanced/bent shaft.
Remember that a 1310 joint is only good for 27deg. So with a ~5" lift at full drop with a stock length driveshaft you may be near or over that. Binding equals blown up stuff :)
JcrOffroad
Zoom Zoom!
Old November 10th, 2005, 01:31 AM   #17
Hal9000
I Ride a Bike
Hal9000's Avatar
Send a message via AIM to Hal9000
yeah i'm in that position myself since i lifted my rig 4.5" , XJ mind you, but yeah, u-joints binding is no good, i'm in need to drop the my t-case also at least a 1"
Hal9000 is offline   Reply With Quote
Old November 10th, 2005, 01:33 AM   #18
Hal9000
I Ride a Bike
Hal9000's Avatar
how much more involved would a motor mount lift be? I'm assuming they make lift brackets already? so you would just need to lift the engin up with a crane and replace the mounts?
Page generated in 0.46055 seconds with 77 queries
