Brakes lock - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 7th, 2007, 01:03 PM   #1
rkcbvw
rkcbvw's Avatar
Default Brakes lock
My brakes keep locking up on the drivers side rear on my 2000 f-150. I pulled the caliper off, cleaned it and put it back on only to have the problem come back after a couple days. Is this air in the line or do I need a new caliper? I recently replaced the pads that where 100% gone, but I left the rotor as is, is it possible my rotar warn or is too thin causing the lock?
rkcbvw is offline   Reply With Quote
Old March 7th, 2007, 03:02 PM   #2
bigblue2230
still goin
bigblue2230's Avatar
does that rear brake have a hat drum/caliper? are there drum brakes on the inside of the rotor or is the parking brake built into the caliper? It might not be the caliper locking up, but the small drum inside. Just a thought. Might have also damaged the caliper by letting it go out all the way with the old pads. It might have shanked the cylinder.
bigblue2230 is offline   Reply With Quote
Old March 7th, 2007, 04:54 PM   #3
rkcbvw
rkcbvw's Avatar
it does have a built in drum for the parking brake which I never use because I have had those freeze up on me before. If I don't use the emergency brake could that still lock up?
Good point, would you take the caliper apart or just put in a rebuild?
Old March 8th, 2007, 08:50 AM   #4
bigblue2230
still goin
I would probably just put a new one in.
Page generated in 0.20425 seconds with 35 queries
