HVAC Question, Bryant Furnace - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 7th, 2007, 06:53 AM   #1
AWK
AWK's Avatar
Default HVAC Question, Bryant Furnace
My furnace just decides to stop. It a Bryant 80-85% Eff. Has the small exhaust blower (black wheel). If I go down there and turn the power off and turn a small switch off inside, then turn them back on, the furnace starts back up and runs for a few days, maybe weeks.
Anyone had this problem before, if so, what did you do to fix it. My barber told me she had the same problem and that it was dirty sensor, but couldn't tell me what one or where it is.
Any insight would be helpful.
AWK
AWK is offline   Reply With Quote
Old March 7th, 2007, 06:57 AM   #2
SinisterX
I Drank WHAT!
SinisterX's Avatar
Send a message via MSN to SinisterX
check/clean your drain tube, the elbow area collects dirt, traps moisture and will mess up the sensor.
SinisterX is offline   Reply With Quote
Old March 7th, 2007, 07:08 AM   #3
AWK
AWK's Avatar
Thanks, I'll do that tonight.
Old March 7th, 2007, 10:18 AM   #4
Bones
Bones's Avatar
mine does the same thing...
what/where is the drain tube?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old March 7th, 2007, 11:07 AM   #5
Calvynandhobbs
Calvynandhobbs's Avatar
Mine's been doing that for the past couple months. Please let me know where this drain tube is.
Calvynandhobbs is offline   Reply With Quote
Old March 7th, 2007, 11:14 AM   #6
AWK
AWK's Avatar
Wow... I'm not alone! I'm assuming this is the drain tube from the condensor core for the AC. Mine is a off white PVC. If you mean something different please enlighten me.
AWK
Old March 7th, 2007, 01:53 PM   #7
shawn
Resident HVAC/R Jambi
shawn's Avatar
You won't have a drain tube on something less than 90% efficiency. Are these furnaces have a control board with a trouble light on it? Does the light ever blink? Usually, if there is a problem, the light will flash in a sequence to tell you what happened. Turning the power off just resets it, until it encounters that problem again. Usually it is the flame sensor, or ignitor that gives problems like this, intermitent.
shawn is online now   Reply With Quote
Old March 7th, 2007, 02:01 PM   #8
SinisterX
I Drank WHAT!
SinisterX's Avatar
The drain tube is in the blower compartment on mine, but like shawn stated you may not have one and you are just resetting the controller. Another thing to check is the exhuast pipe outside. They put a grill over then end to keep birds and mice out of the tube but during certain weather conditions it gets frosted up and faults the controller. I remove the grill in the winter.
Old March 7th, 2007, 02:01 PM   #9
Bones
Bones's Avatar
so i need to look for a blinking light on the control board eh?
To reset mine, I can either flip the switch on the unit itself, or I can turn the thermostat from 'heat' to 'off' and then back to 'heat' and it starts up again...
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old March 7th, 2007, 02:23 PM   #10
xj4life
xj4life's Avatar
send a PM to TJrockdogg. he installed my furance. he should be able to help you out.
Page generated in 0.26655 seconds with 52 queries
