Rubber flap under engine in XJ'S??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 23rd, 2006, 05:15 PM   #1
Ready4Wheelin
Ready4Wheelin's Avatar
Default Rubber flap under engine in XJ'S???
What useful purpose (if any) does this serve?? Does it really keep that much mud/dirt out of the engine compt.?? Mine's always falling down and unless there's some REAL significance to it, I'm going to rip it out. :stan3: I searched the forums but couldn't find a match so sorry if this is a ...just wondering if anyone has taken theirs out!!! Thanx for the input!!
Ready4Wheelin is offline   Reply With Quote
Old January 23rd, 2006, 05:34 PM   #2
muddslinger
muddslinger's Avatar
Send a message via AIM to muddslinger
ive got the same thing in my yj, not sure what exactly it does, just kinda sits there, i guess it probably blocks water from splashing into the intake
muddslinger is offline   Reply With Quote
Old January 23rd, 2006, 05:38 PM   #3
One Arm Steve
I was born in the desert
One Arm Steve's Avatar
I removed mine years ago. The only problem I can see is that the alternator is at risk of being damaged from water and dirt because its so low. I guess you will have to lift your XJ higher to keep the elements away from it.
One Arm Steve is offline   Reply With Quote
Old January 23rd, 2006, 06:46 PM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
you have the right idea, I have ripped off hundreds over the years for what I do to jeeps, the splash shield as its called is to prevent undue crap & water getting in the belts and causing a premature failure of the belt drive and its componants, keep it clean and it stays running if you know what I mean.
Yetti
Old January 23rd, 2006, 06:49 PM   #5
Ice Princess
I'm just here
Ice Princess's Avatar
Send a message via AIM to Ice Princess Send a message via MSN to Ice Princess
I've noticed the same thing on my XJ too. It's still there but I haven't notice any problems with it. It's just there.
Ice Princess is offline   Reply With Quote
Old January 24th, 2006, 09:18 AM   #6
Ready4Wheelin
My XJ's lifted 3.5", so maybe that's enough to keep some stuff out, but has anyone ever expirienced any of these problems with it removed??
Old January 24th, 2006, 09:28 AM   #7
FrankNBrew
Me balls are huge
FrankNBrew's Avatar
Yes. After removing the rubber shield my belt squeals when I hit water puddles.
FrankNBrew is offline   Reply With Quote
Old January 24th, 2006, 05:29 PM   #8
Ready4Wheelin
Killer lookin' XJ, Frank!! Am I correct in assuming the squeal goes away after a second or two???
Old January 25th, 2006, 09:39 AM   #9
FrankNBrew
Me balls are huge
FrankNBrew's Avatar
Thanks! And yes, the squeal goes away after a few seconds.
Page generated in 0.17355 seconds with 50 queries
