Disc brakes for Ford HP44? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 6th, 2007, 05:43 PM   #1
BlaineWasHere
GVSU Jeeper
BlaineWasHere's Avatar
Send a message via AIM to BlaineWasHere
Default Disc brakes for Ford HP44?
I am thinking about swaping a HP44 into the front of my dub. 5on5.5 lug outers... Did any of them come with disc brakes or are there any kits?
BlaineWasHere is offline   Reply With Quote
Old March 6th, 2007, 05:45 PM   #2
PavementPounder
PavementPounder's Avatar
Uh, its actually not so common to find them without discs anymore. 1/2 ton units will have the 5x5.5 pattern, but they will have cast ends. The F-250 units will have tubes with welded parts (leaf sprung), but will have 8-lug hardware. You can swap the entire knuckle-out 1/2 ton onto the 8-lug if you don't care about the F-250 factory flat-top knuckles or dual-piston calipers.
Old March 6th, 2007, 10:55 PM   #3
BlaineWasHere
GVSU Jeeper
The 1/2 ton axels are 65" WMS which are perfect for WJ's (63.5" stock) I heard that some 1/2 ton had the arm mounts welded vs cast into the housing.
But the flat top knuckles and big calipers would be nice. I was planning on keeping stock rear for now so I don't know would do to make the rear match...
Old March 6th, 2007, 11:58 PM   #4
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
78-79 had the cast c-bushing mount. F150 prior to that were weld on. Also EB were weld on but only like 58"ish wms
And yes many of them came with disc brakes from the factory. I believe EB started in '73...and F150's started '73 or '74. Also 78-79 full size Bronco's had factory disc brakes. The D44 in the front of my ZJ is from a '79 F150/Bronco..factory disc brakes.
Old March 7th, 2007, 05:56 AM   #5
PavementPounder
If you go with the 8-lug F-250 front, using the matching D60 rear would be the easiest route. The sets are commonly found in 4.10.
Old March 7th, 2007, 09:26 AM   #6
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
The 1/2 tons are 65" wms but if you use a 3/4 ton it is wider at about 68" wms. I would stick with half ton stuff and run the 9" rear also.
Old March 7th, 2007, 09:30 AM   #7
PavementPounder
Cjaholic is selling the F-250 outer setup you can throw on the 1/2-ton front if you consider going 8-lug front and rear, with like a 9" or something.
Old March 7th, 2007, 10:28 PM   #8
BlaineWasHere
GVSU Jeeper
That adds the problem of the speedo. on the WJ it uses the rear axel. No speedo input on my TC.
Maybe I'll just carry spare D30 shafts for now. I can't do front, rear and TC upgrade at the same time.
Old March 8th, 2007, 07:54 AM   #9
Jeepaholic
Jeepaholic's Avatar
Is it just a tone ring in the rear axle? Just find a newer 1/2 ton dodge rear that has a tone ring. You will probably need to get a true speeed to adjust for different readings but it might work. FYI the dodge SRT10 truck used a semifloat disc'd dana 60 rear, I see them time to time on Ebay. You would have to do some more research though.
Old March 8th, 2007, 09:22 AM   #10
BlaineWasHere
GVSU Jeeper
That axel would be 6 lug though? That still does not match the 8 lug front.
Old March 8th, 2007, 10:10 AM   #11
Jeepaholic
Jeepaholic's Avatar
FYI Even if you run the 1/2 ton housing the 3/4 ton outers add an 1" to each side, 67"wms. Look for a late model dodge 3/4 ton dana 60/70 rear if you want to run the 8 lug. I know they have the tone ring for the abs which might work.
Notice the tone ring It is even in MI
http://cgi.ebay.com/ebaymotors/90-Do...QQcmdZViewItem
Old March 8th, 2007, 10:29 AM   #12
PavementPounder
The 1/2 ton Ram axle would be 5-lug.
The tone ring that he suggested may be the actual solution, but you're going to want to target an axle that has a similar sensor attachment.
Page generated in 0.32031 seconds with 59 queries
