MozMan68's "Baddest Daily Driven 4-Banger TJ Ever" - Page 15 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 12th, 2010, 05:21 AM   #281
MusKegon_ZJ_gurl
Extraordinarily Ordinary
MusKegon_ZJ_gurl's Avatar
Wow...
Mozman lives.
http://www.glfwda.org/
MusKegon_ZJ_gurl is offline   Reply With Quote
Old May 30th, 2010, 10:18 PM   #282
MozMan68
Poseur Extraordinaire
MozMan68's Avatar
Default Electric Fan Install
Okay...finally...my electric fan install. Fan is a two-speed Taurus fan I picked up from a Two Tracker for $20.
I cut the coolant bottle bracket portion off the old shroud and screwed it to the new fan. Power steering bottle is zip-tied to the coolant bottle. Seems pretty stable even if it is ghetto fabbed.
Here's the DC Control unit...I mounted it to the inner fender well below the air box simply because it was close to the fan wires and there was plenty of room there.
Here's a view from the passenger side. Attached the fan ground to the top of the c-clip. Routed the battery wire from the DC Control unit along the battery cable from the winch. The ignition and ac control wore are routed up the passenger side and across the firewall.
Used a 30 amp fuse between the DC Control unit and the battery.
The AC control wire is spliced into the AC 12v wire (blue with black stripe) right off the connector on the firewall.
Ran the ignition wire from the DC Control unit to a toggle switch that is grabbing power from the cigarette lighter. Allows me to shut down the fan for water crossings.
MozMan68 is offline   Reply With Quote
Old May 31st, 2010, 07:15 PM   #283
creeping death
I'm that guy.
creeping death's Avatar
Originally Posted by MozMan68 View Post
fan looks good Moz but there sure is alot of room in under that hood.
Old May 31st, 2010, 08:09 PM   #284
MozMan68
MozMan68's Avatar
Now I have a place to store contraband.....
Old May 31st, 2010, 08:18 PM   #285
creeping death
I'm that guy.
Old April 11th, 2013, 10:36 AM   #286
MozMan68
MozMan68's Avatar
Does moving up to 37's count as enough of a reason to update my build thread?
Old April 11th, 2013, 03:22 PM   #287
Bossman63
Two Trackers 4x4 Member
Bossman63's Avatar
Sure it does. I put a Dodge Durango steering box on my 2002 TJ ... Didn't feel the need to do a write up on it though ...
Two Trackers Four Wheel Drive Club Member
Bossman63 is offline   Reply With Quote
Old April 11th, 2013, 05:18 PM   #288
MozMan68
MozMan68's Avatar
Okay...maybe when I start putting the turbo diesel in then....
Tags
baddest 4 banger tj ever
Page generated in 0.22011 seconds with 48 queries
