Need a set of V-8 engine mounts - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 5th, 2007, 03:58 PM   #1
ovr-ez
ovr-ez's Avatar
Default Need a set of V-8 engine mounts
I am going to swap a 360 into my 82 CJ-7 and need a set of engine mounts for a V-8. If you have a set for sale please let me know.
Thanks,
Joe
jeepincj8@yahoo.com
ovr-ez is offline   Reply With Quote
Old March 5th, 2007, 04:46 PM   #2
PavementPounder
PavementPounder's Avatar
Locations are a GL4x4 Marketplace requirement. Please provide your location in accordance with the GL4x4 Marketplace Rules. Your User Profile is the recommended location for providing the info, as it will then appear in all your Marketplace threads automatically.
You may review the details of the GL4x4 Marketplace Rules here.
You may review the recent announcement which provides clarification on the issue of locations here.
Old March 5th, 2007, 05:30 PM   #3
Sandals
Fucking Zen as Shit
Sandals's Avatar
Which motor mounts???
Do you need the weld in frame mounts? or do you need the steel pieces that bolt to the block?
if it's the latter I have several sets.
Old March 5th, 2007, 05:37 PM   #4
PavementPounder
CJ frame mounts are bolt-in, not weld-in. He needs it all to bolt-in a V8 - the frame mounts, motor mounts, and block mounts. The block mounts are not the same as FSJ.
Old March 5th, 2007, 07:25 PM   #5
ovr-ez
ovr-ez's Avatar
What he said. Thanks
Old March 5th, 2007, 09:40 PM   #6
dmcjeep
dmcjeep's Avatar
I have a set of block mounts. Might have the frame ones also but I have to check and make sure. Even though they are bolt in you may have a problem bolting them into a 82 or newer cj.
dmcjeep is offline   Reply With Quote
Old March 5th, 2007, 09:44 PM   #7
PavementPounder
No, he won't. The pattern of 6 bolt holes remained on each frame rail until the end.
Page generated in 0.24361 seconds with 44 queries
