EGR code won't leave, WTF??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 4th, 2007, 09:49 PM   #1
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
Default EGR code won't leave, WTF???
'98 k1500 5.7/auto.
I keep getting the 404 EGR flow code on my Silverado, I replaced the EGR valve, passages looked clear, and just installed new converters. Cleared all codes with scanner, go for a short drive and still get this code. What gives??
Old March 6th, 2007, 08:02 AM   #2
Trail-XJ
Bank Account Understands!
Trail-XJ's Avatar
Originally Posted by CHVYPWR View Post
'98 k1500 5.7/auto.
An exhaust gas recirculation (EGR) system is used in order to lower oxides of nitrogen (NOx) emission levels caused by high combustion temperatures. The EGR accomplishes this by feeding small amounts of exhaust gases back into the combustion chamber. When the air/fuel mixture is diluted with the exhaust gases, combustion temperatures are reduced.
A linear EGR valve is used on this system. The linear EGR valve is designed in order to accurately supply exhaust gases to the engine without the use of intake manifold vacuum. The valve controls exhaust flow going into the intake manifold from the exhaust manifold through an orifice with a control module controlled pintle valve. The control module commands the EGR by applying a 12 volt duty cycle to the EGR valve. This can be monitored on a scan tool as desired EGR position.
The control module can monitor the pintle position with the EGR pintle position signal. This sensor uses a variable resistor with a 5 volt reference, a signal circuit, and a ground. The signal circuit monitors changes in voltage on the variable resistor as the pintle moves.
The VCM will set a DTC P0404 if it detects a large enough difference between desired EGR and actual EGR.
Conditions for Running the DTC
The ignition voltage is more than 9 volts
Conditions for Setting the DTC
The difference between the actual EGR position and the desired EGR position is more than 10 percent for more than 10 seconds
Action Taken When the DTC Sets
The control module illuminates the malfunction indicator lamp (MIL) the first time the diagnostic runs and fails.
The control module will set the DTC and records the operating conditions at the time the diagnostic fails. The control module stores the failure information in the scan tools Freeze Frame/Failure Records.
Conditions for Clearing the MIL or DTC
The control module turns OFF the MIL after 3 consecutive drive trips when the test has run and passed.
A history DTC will clear if no fault conditions have been detected for 40 warm-up cycles. A warm-up cycle occurs when the coolant temperature has risen 22C (40F) from the startup coolant temperature and the engine coolant reaches a temperature that is more than 70C (158F) during the same ignition cycle.
Use a scan tool in order to clear the DTCs.
Diagnostic Aids
Excessive carbon deposits may cause a restriction of movement in the EGR pintle. This problem may be compounded in cold weather with moisture freezing in the valve. Check for full range operation in the EGR system with the scan tool.
Check for excessive exhaust back pressure. Refer to Restricted Exhaust System Check .
An intermittent may be caused by any of the following conditions:
A poor connection
Rubbed through wire insulation
A broken wire inside the insulation
Thoroughly check any circuitry that is suspected of causing the intermittent complaint. Refer to Intermittents and Poor Connections Diagnosis in Wiring Systems.
If a repair is necessary, refer to Wiring Repairs or Connector Repairs in Wiring Systems.
Test Description
Number(s) below refer to the step number(s) on the Diagnostic Table.
This step will determine if the VCM can control the EGR valve.
Commanding the EGR valve to the specified values determines whether the VCM can control the EGR valve accurately. Production variations may not allow the EGR valve to be commanded to 100%.
There are certain circuits in the VCM C4 connector that could cause a short to voltage to the EGR valve control circuit that may disappear when the C4 connector is disconnected. By checking each individual circuit for a short to the EGR valve control circuit with a DMM will confirm if such a condition exists.
If the EGR valve 5 volt reference is shorted to voltage, the DMM will read battery voltage and additional DTCs may be set.
A problem may exist within the terminals which would not show up in probe type testing. Be sure to check the terminals for being backed out, improperly formed, or damaged.
Clearing the DTCs is a very important step for this diagnostic. The clearing function allows the EGR valve to relearn a new minimum pintle position.
Trail-XJ is offline   Reply With Quote
Old March 6th, 2007, 08:02 AM   #3
Trail-XJ
Trail-XJ's Avatar
thats from GM Service Info on that code
Old March 6th, 2007, 08:02 AM   #4
Trail-XJ
Trail-XJ's Avatar
Important
Before clearing the DTCs, use the scan tool Capture Info to save the Freeze Frame and Failure Records for reference. The control module's data is deleted once the Clear Info function is used.
Did you perform the Powertrain On-Board Diagnostic System Check?
Go to Step 2
Go to Powertrain On Board Diagnostic (OBD) System Check
2
Start the engine.
Command the EGR valve to the specified value using a scan tool.
Does the engine run rough or stall?
50%
Go to Step 3
Go to Step 5
3
Turn OFF the engine.
Turn ON the ignition leaving the engine OFF.
Command the EGR valve to the specified values using a scan tool.
Does the actual EGR position closely follow the commanded position?
0%, 20%, 50%, 70%, 100%
Go to Step 4
Go to Step 10
4
This DTC is intermittent.
Are any other DTCs set?
Go to the applicable DTC table
Go to Diagnostic Aids
5
Disconnect the EGR valve harness connector.
Probe the EGR valve control circuit at the EGR valve harness connector with a test lamp connected to a ground.
Is the test lamp ON?
100%
Go to Step 6
Go to Step 7
6
Probe the EGR valve ground circuit at the EGR valve harness connector with a test lamp connected to B+.
Go to Step 21
Go to Step 9
7
Check the EGR valve control circuit for a short to ground between the VCM and the EGR valve harness connector using a test lamp connected to B+.
Repair as necessary. Refer to Wiring Repairs in Wiring Systems.
Did you find a problem?
Go to Step 25
Go to Step 8
8
Check the EGR valve control circuit for an open between the VCM and the EGR valve harness connector using a J 39200 DMM.
Go to Step 25
Go to Step 23
9
Check the EGR valve ground circuit for an open.
Go to Step 25
Go to Step 23
10
Caution: Avoid contact with moving parts and hot surfaces while working around a running engine in order to prevent physical injury.
Start the engine.
Go to Step 11
Go to Step 13
11
Turn OFF the ignition.
Disconnect the VCM C4 connector.
Go to Step 17
Go to Step 12
12
With the VCM C4 connector still disconnected, check the EGR valve control circuit for a short to all of the other circuits in the C4 connector.
Are there any circuits shorted to the EGR valve control circuit?
Go to Step 18
Go to Step 24
13
Measure voltage between the 5 volt reference circuit at the EGR valve harness connector and a ground with a J 39200 DMM.
Is the voltage above the specified value?
5.2 V
Go to Step 19
Go to Step 14
14
Measure the voltage on the EGR valve pintle position signal circuit at the EGR valve harness connector with a J 39200 DMM connected to a ground.
Is the voltage at the specified value?
0 V
Go to Step 16
Go to Step 15
15
Check the EGR pintle position signal circuit between the EGR valve harness connector and the VCM for a short to voltage.
Go to Step 25
Go to Step 24
16
Probe the EGR sensor ground circuit at the EGR valve harness connector with a test lamp connected to B+.
Go to Step 21
Go to Step 20
17
Repair the short to voltage to the EGR valve control circuit. Refer to Wiring Repairs in Wiring Systems.
Is the action complete?
Go to Step 25
18
Repair the short to the EGR valve control circuit. Refer to Wiring Repairs or Connector Repairs in Wiring Systems.
Go to Step 25
19
Repair the short to voltage in the 5 volt reference circuit. Refer to Wiring Repairs in Wiring Systems.
Go to Step 25
20
Disconnect the VCM C3 connector.
Check the EGR sensor ground circuit between the VCM and the EGR valve for an open.
Go to Step 25
Go to Step 23
21
Check for a poor connection at the EGR valve. Refer to Connector Repairs in Wiring Systems.
Go to Step 25
Go to Step 22
22
Replace the EGR valve. Refer to Exhaust Gas Recirculation (EGR) Valve Replacement .
Go to Step 25
23
Check the VCM connectors for a poor connection. Repair as necessary. Refer to Connector Repairs in Wiring Systems.
Go to Step 25
Go to Step 24
24
Replace the VCM.
Program the new VCM. Refer to VCM Replacement/Programming .
Perform the Password Learn Procedure. Refer to Password Learn Procedure .
Perform the CKP System Variation Learn Procedure. Refer to CKP System Variation Learn Procedure .
Go to Step 25
25
Using the scan tool, clear the DTCs.
Start the engine.
Allow the engine to idle until the engine reaches normal operating temperature.
Select DTC and the Specific DTC function.
Enter the DTC number that was set.
Operate the vehicle, within the Conditions for Setting this DTC, until the scan tool indicates the diagnostic Ran.
Does the scan tool indicate the diagnostic Passed?
Go to Step 26
Go to Step 2
26
Does the scan tool display any additional undiagnosed DTCs?
System OK
Old March 6th, 2007, 08:03 AM   #5
Trail-XJ
Trail-XJ's Avatar
and theres the diag. chart
Old March 6th, 2007, 11:05 AM   #6
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
Holy chit! Thats alot of info, thanks!
Page generated in 0.74851 seconds with 41 queries
