Welder repair/modification... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 3rd, 2007, 09:17 PM   #1
artistic_gore
I own @ halo
artistic_gore's Avatar
Send a message via AIM to artistic_gore
Default Welder repair/modification...
The knob for speed control on my welder is broken off, it has been since I've owned the thing I just haven't taken the time to fix it yet. I am thinking of going to radio shack to find a replacement but I have a couple few questions.
How do I test the pot to find a suitible replacement? 5k ohm, 10k ohm, I don't know what I need. Should I just put my multimeters leads on different combos of leads on the pot (i can't remember if it has 3 or 4) and see what kind of readings I can get?
Would it be possible to relocate both the speed and heat controls out to my stinger? attach a small enclosure somewhere out of the way with two pots in it and wires strung out in a seperate enclosure from my main lead. I don't think the sleeve that the main lead and gas line are in would accomodate the extra girth. Also what gauge wire would i have to use in this situation. It's just a little 120volt mig, I can't remember the amps off the top of my head.
As usual any help would be appreciated.
Thanks,
Bryce
artistic_gore is offline   Reply With Quote
Old March 4th, 2007, 08:34 AM   #2
Thanks,
Bryce
Here's what I'd do:
Take it apart, and measure between all the terminals. So if there's 3 terminals, measure between 1-2, 1-3, and 2-3. Also post a nice close up picture. Report back your findings and picture and we'll try to help more.
You might be lucky, and its printed on the back of the case. Probably a 10k but go look.
Old March 4th, 2007, 11:38 AM   #3
mlfreund@mtu.edu
Traverse Mi
mlfreund@mtu.edu's Avatar
contact the dealer??
mlfreund@mtu.edu is offline   Reply With Quote
Old March 4th, 2007, 02:32 PM   #4
artistic_gore
I own @ halo
The "dealer" is sears, I can't afford the prices they want for simple repairs/parts like this. Also I called them and they weren't any help on the phone. Also they want me to replace the card the pot is attached to instead of just the pot itself. It's a difference of like $50 IIRC, maybe more. I checked it today and found that two of the leads on the pot were soldered together so I just checked between those and the other one and came up with 1.1K ohms on the pot that has to be replaced. On the other it was the same situation with solder joining two pots, it came out to 9.7k ohms. I can take pics later but I couldn't find my camera earlier when I went out to the garage.
Old May 3rd, 2007, 09:18 PM   #5
MrBi11
When you measure [with the set-up described] the value between the two connected leads and the third will be the measurement you want. Make sure knob is turned all the way to give you the maximum resistance.
MrBi11 is offline   Reply With Quote
Page generated in 0.23746 seconds with 38 queries
