Stuck in 4 Low - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 3rd, 2007, 04:53 PM   #1
FORD FLARESIDE
Headed to Nationals 2017!
FORD FLARESIDE's Avatar
Default Stuck in 4 Low
Well...............has anybody come across this before.
My F150 (302, E04d,Borge Warner t-case) seems to have an issue.
I put it into 4 -low, heard a little bit of clattering, and now it will not come out of 4 low. I can run the lever between 4 high, 4low and 2 high, but it stays in 4 low. Also it will only shift manually 1st, 2nd, and reverse. Drive gear, will not shift through, it just stays in first.
This happened once last summer when I was on the dunes, but once I put it in to 2high a couple times it started working again.
I checked the linkage to the T-case from the tranny and that is still connected. However, the shaft for the lever on the t-case (connected to the tranny) will move in and out of the t-case about 1/4 of an inch.
Any suggestions?
Oh and by the way, this T-case has about 7000 miles on it since it was rebuilt, and to be honest the other parts on this truck that this so called mechanic touched have also broke and been replaced.
Please help, I'm sick of being taken advantage of.
Old March 3rd, 2007, 05:47 PM   #2
gotsand?
sie sehen mich rollin ...
gotsand?'s Avatar
Location: New Era, MI --- "We passed BFE 35 minutes ago."
Send a message via Yahoo to gotsand?
have someone hold the shaft in, while someone else changes range.....maybe a pin broke, and when you try shifting it, this shaft pops out.
gotsand? is offline   Reply With Quote
Old March 3rd, 2007, 09:36 PM   #3
jontboudrie
jontboudrie's Avatar
Default stuck in 4 low
yup mine is same way. its a shift fork broke. i can get mine fixed for a 100.
jontboudrie is offline   Reply With Quote
Old March 3rd, 2007, 10:01 PM   #4
FORD FLARESIDE
So the next step is pulling the t-case and splitting it apart?
Old March 6th, 2007, 08:53 PM   #5
chris1044
chris1044's Avatar
Yep, and if it's never been apart before, time for a chain.....
They're really not that hard to do though.....
Old March 7th, 2007, 06:22 AM   #6
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
Note to self....don't use whatever mechanic friend Ford Flairside uses
Old March 7th, 2007, 07:15 AM   #7
FORD FLARESIDE
Amen.
Page generated in 0.24569 seconds with 44 queries
