99 montecarlo - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 3rd, 2007, 05:01 PM   #1
biggs-cj
biggs-cj's Avatar
Default 99 montecarlo
my sons 99 montecarlo has puked......he stoped at a light and it started to run like it was running out of gas,he drove about a block and it puked......i,ve checked the fuel pump ,and its working fine,,,,,,,,, i ,ve tried to get it running but all it does is fire alittle but wont start???anyone know about these cars??? what shoud i look for,,,,,,,i need to get it running again......
biggs-cj is offline   Reply With Quote
Old March 3rd, 2007, 06:03 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
well if your dealing with a 3100 I think the first place to start is the throttle body. they gum up really bad and create all kind of horrors for the unsuspecting owners. the second thing is ignition coils & wires. they have a bad set up in the fact the coils can fry one at a time and then drop plugs. the idea here is to identify if your loosing spark to any cylinders. clean the throttle body & butterfly with carb clean and a tooth brush while your there. let me know what you find.
Yetti
Old March 4th, 2007, 07:39 PM   #3
biggs-cj
biggs-cj's Avatar
thanks i,ll check those out
Old March 6th, 2007, 08:04 AM   #4
Trail-XJ
Bank Account Understands!
Trail-XJ's Avatar
check the fuel pressure, if it drops off after the key is turned off you might have a stuck injector bleeding the fuel into the cylinder causing a flooding
concern. pull the plugs and take a look!
Trail-XJ is offline   Reply With Quote
Old March 10th, 2007, 10:45 AM   #5
biggs-cj
biggs-cj's Avatar
well got it running,,,its a 3800 though,,,,,,,changed out the plugs ,4 were fouled out (from trying to start it so much i guiss) had to change idle control senser to ..........but now it floods out and smokes alot of white smoke after you get it restarted and runs like a four popper not a six?? but not ever time though? some time it runs fine ?.....never had this problem before....ive checked the oil for water or gas ,and it looks fine,,,,dont know what the hells going on now???
Old March 10th, 2007, 02:58 PM   #6
frdboy
frdboy's Avatar
Check the coolant level, lots of problems with the upper intake manifold melting internally at the egr port, dumps coolant into intake manifold. I have replaced several engines due to hydro-locking and bending rods.
On the early ones (96-97 3800) we would have to replace both the upper and lower manifolds and reprogram the pcm, but GM came out with a updated lower intake manifold in 98 so your car should have it. If this is the problem I would recommend replace the upper manifold, (Dorman makes one) and replace the lower intake gaskets as these are probably leaking anyway.
If you are sure that is not the problem then pull the vac. hose off the fuel pressure regulator mounted on the fuel rail and check for any signs of fuel, it should be dry, I have replaced many for leaking fuel into the intake via the vac. hose.
hth
Adam
Old March 10th, 2007, 08:14 PM   #7
djlipp
998,999,1000
djlipp's Avatar
X2 what he said
djlipp is offline   Reply With Quote
Old March 12th, 2007, 09:40 AM   #8
biggs-cj
biggs-cj's Avatar
well it was running fine sunday ,no leaks no smoke ran great..........intell he got into lansing couple pings ,and now its seized,,,,,,,,,,well i dont have to worry about that motor now
Old March 29th, 2007, 09:58 PM   #9
Trail-XJ
Trail-XJ's Avatar
sounds like it was that intake leaking coolant into the engine, if it didn't bend rods you can un-hydrolock it sometimes. i unlocked a 3800 buick lesabre 3 times.
Page generated in 0.33505 seconds with 50 queries
