13, 14 or 15 inch tires on a trailer? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 3rd, 2007, 02:11 PM   #1
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Default 13, 14 or 15 inch tires on a trailer?
Ok, looking for pro's and cons for the 3 tires sizes on a tandem car hauler. It's a short trailer with 3500 pound axles. Seems the load range is the same for the most part on all 3 tires.
The trailer is only going to haul smaller cars, short distance and haul the YJ longer distances.
Any opinions?
Old March 3rd, 2007, 03:15 PM   #2
Mongo
Mongo's Avatar
The 13's will make loading easier and keep the COG lower, but IIRC the 15's will last longer. Something about the larger diamater being better at highway speeds.
Mongo is offline   Reply With Quote
Old March 3rd, 2007, 04:55 PM   #3
sodapop
Support the Sport!
sodapop's Avatar
The larger diameter tire will make less revolutions and so it should theoretically last longer. In theory it might also be easier on the bearings too. As for lower and ease of loading, well you also have to worry about dragging your tail when you are pulling it round and in the grass too.
Old March 3rd, 2007, 05:47 PM   #4
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Bigger is better. Better load carrying and less revolutions, which will keep the tire and bearings cooler.
Old March 3rd, 2007, 06:55 PM   #5
x2
And put radials on your braking axles (which should be both)
Old March 3rd, 2007, 07:06 PM   #6
Kawierider
Kawierider's Avatar
I thought you wanted bias ply's on a trailer ? I've heard that radials make lots of sway
Old March 3rd, 2007, 07:27 PM   #7
Bias plies for non brake axles, radials for brake axles.
And for our needs, all axles legally require brakes in michigan.
Old March 3rd, 2007, 07:41 PM   #8
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
COG and easier loading for little cars and crap that I have to haul around town.
Yea, radials on both axles is what I am going to do. I thought about the cooler bearings and longer lasting tires...but for the few times a year I haul the Jeep, is it really that big of a deal if you keep the bearings serviced?
I know the law says so, but I see a ton of trailers with only 1 brake...and I see even more with brakes but the tow rig doesn't have a controller.:stan3:
I wanted to convert to surge brakes, but too much work and too much cost.
Old March 3rd, 2007, 08:28 PM   #9
And no fun backing up in anything that puts resistance on the trailer..
Old March 3rd, 2007, 08:43 PM   #10
Grandman
do i look old !
Grandman's Avatar
The law does not require any brakes unless you are over 5,000 GVW . I am not aware of a law requiring both axles to have brakes and i dont think they would build it with only 1 if the law required both .
I my self would not run a trailer with out brakes on both .
Old March 3rd, 2007, 09:03 PM   #11
Freak
Wheelin the HD
Freak's Avatar
I don't understand the whole brakes thing, I towed a full sized suburban on a dolly with my 89 f150! it stopped just fine after pushing me about 5 feet.
Old March 3rd, 2007, 09:45 PM   #12
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Most have a release switch that makes it so the brakes don't apply when you want to backup.
It's a pain sometimes, but not usually, I had it on my old boat trailer.
The new one is wired in...when you put it in reverse, it takes a signal from the backup lights and closes a solenoid and doesn't allow the brakes to work....sorta like a line lock.
New surge brakes are far better then the old crap.
Old March 4th, 2007, 12:08 AM   #13
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
boat trailers have surge brakes because they can't have all the electrical stuff submerged all the time. They actually do offer a water proof electric brake setup now.
Personally I think electric brakes are a lot better because you can control the brakes independantly of the truck. Which is useful more often than you think.
JcrOffroad
Zoom Zoom!
Old March 4th, 2007, 06:52 AM   #14
Did a quick search. Found the state police inspection sheet. Look in section D. States brakes on all wheels if 5500 pounds. I haven't found the actual law.
http://www.michigan.gov/documents/TR-54_38480_7.pdf
I also found several rv and boat sites that state brakes are required over 3000 pounds.
As far as the tire size, I would go with the 15". Keep in mind that the actual trailer deck height is only 1" higher with a 2" taller tire. I have had my share of trailer tire issues over the years. Personally I don't like radials because of the sway. They are also visually harder to determine if they are low on tire pressure when doing a simple walk around inspection during fuel stops. I never get anthing but "D" rated bias now.
And like the other guys said, larger tire equals slower revolutions and cooler bearings.
just my .02
Old March 4th, 2007, 07:03 AM   #15
Viperdave
A-1 Dave Costa
Send a message via AIM to Viperdave
i know with my open car trailer on 225/70R15 i have no sway at all. My enclosed sled trailer is on 205/70R15 and that only has sway when unloaded. The big thing in preventing sway is making sure the trailer is loaded evenly and that it sits flat when loaded...
Viperdave is offline   Reply With Quote
Old March 4th, 2007, 07:09 AM   #16
Viperdave
A-1 Dave Costa
in terms of size and revolution
a 225/70R15 travels 736 revolutions per mile
a 175/80R13 travels 840 rev/mile or about 12.4% more rev per mile
which also means that when travelling at 70 your trailer tires will be if 175/80R13 will be doing a comparitive 78.8 mph
Old March 4th, 2007, 10:03 AM   #17
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
My 28 foot Cobia (18 years old) boat sits on a 14 year old trailer that has electric brakes.
Old March 4th, 2007, 05:05 PM   #18
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Huh, that's cool. Not many of those around.
JcrOffroad
Zoom Zoom!
Old March 4th, 2007, 07:59 PM   #19
just my .02
In the Michigan Vehicle Code, it states:
257.705 Brakes.
Sec. 705.
(1) Brake equipment shall be required as follows:
(d) A new motor vehicle, trailer, or semitrailer sold in this state and operated upon the highways shall be equipped with brakes on all wheels, except a motorcycle or moped, and except that a semitrailer, pole trailer, or trailer of less than 3,000 pounds gross weight need not be equipped with brakes if the gross weight of a trailer or pole trailer, no part of the load of which rests upon the towing vehicle, does not exceed 40% of the gross weight of the towing vehicle, and if the gross weight of the towing vehicle and the gross weight of a semitrailer or pole trailer, part of the load of which rests upon the towing vehicle, does not exceed 40% of the gross weight of the towing vehicle when connected to the semitrailer or pole trailer. This subdivision shall not apply to a trailer or semitrailer owned by a farmer and used exclusively in connection with the farming operations of the farmer and not used for hire.
Gross weight being defined as:
257.19 “Gross weight” defined.
Sec. 19.
“Gross weight” means the weight of a vehicle without load plus the weight of any load thereon.
So, what that means is that EMPTY you don't need brakes on most flatbed, which weigh in around 1500-2000 lbs unloaded. But when you've got a 4x4 up there your trailer gross weight is ~5000-7000 lbs, which is usually more than 40% of your tow vehicle, which for most of us is ~7000-12000 lbs.
So, even the baddest Dodge 3500 out today, which has a gross vehicile weight rating of 12200 lbs can't legally tow a stock TJ on an average trailer without 4 wheel trailer brakes. Bu tit can tow that trailer empty with no brakes.
Old March 4th, 2007, 09:07 PM   #20
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Ahhhhhh, but wouldn't that read as a "new" trailer? Like older trailers with only 1 brake are ok?
My 21 foot only has brakes on 1 axle and the SOS said it was ok when I registered it.
Page generated in 0.50648 seconds with 83 queries
