'76-'86 CJ rear axle swap options - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 1st, 2007, 12:17 PM   #1
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Default '76-'86 CJ rear axle swap options
I thought I'd post a link to a FAQ page I put together for cj-8.com. It lists various \\\\\\\\\\'76-\\\\\\\\\\'86 CJ rear axle swap options. If you have any input about the content, let me know.
Craig
Old March 1st, 2007, 12:25 PM   #2
PavementPounder
PavementPounder's Avatar
  • I don't recall the D60-2 I used to have being offset. I sold it to Fullthrottle and its now underneath 84Scrambler's Scrambler. Quadra-trac was a new and popular option during the end of the period that D60-2's were being used, so there may have been both centered and offset versions. That width sounds a little wide to me, also. I think the 74 J-20 rears I have are only 62"ish wide (as you stated) and they are newer. Perhaps one of those two clowns can provide some input. 4.27 was another common ratio during that era.
  • The J-series D60 rears were used right up to the end in the 80's. They are 8x6.5 and 30-spline. They were offered in both centered and offset for Quadra-trac. Common gear ratio was 3.73.
Old March 1st, 2007, 04:19 PM   #3
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
The J-Truck D60-2 was offset. I have owned 3 of them, and seen 4 others. The ones that were for sale on eBay from Market2 were centered, but they weren't ever under used under a vehicle, supposedly just for testing. Jeep used the Spicer 18 t-case during that time period, which was also offset. Pretty sure my '67 M715 even had an offset rear with a centered t-case- I have seen this in a few of the FSJs.
Old March 4th, 2007, 10:38 AM   #4
fabricator
throttle jockey
fabricator's Avatar
the last one i used was around 65 wms and offset around 5 inches. i shortened the long side tube to use another matching short side axle shaft. made a nice 60 wms axle with 35 spline 5 on 5 1/2 shafts using all stock parts. rear axle shaft bearings were not easy to find. had to get factory spicers.
fabricator is offline   Reply With Quote
Page generated in 0.15587 seconds with 35 queries
