setup tools - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 28th, 2007, 07:09 PM   #1
greenmeanie
greenmeanie's Avatar
Default setup tools
what tools other than a dial indicator/magnetic base do i need in order to install gears and make a proper mesh pattern on my dana 44 and 30? i'll need shims and bearings too, but are there any other parts i may need? thanks
greenmeanie is offline   Reply With Quote
Old February 28th, 2007, 08:03 PM   #2
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Torque wrench?
Old February 28th, 2007, 08:09 PM   #3
Mclovin
"The Situation"
Mclovin's Avatar
just put in what you take out with the old shit and run it.. :tonka:
Old February 28th, 2007, 08:19 PM   #4
Jeeptj1999
Jeeptj1999's Avatar
It doesn't matter if you know how to do it or not, just go slow and take your time, it will be fine.........
Jeeptj1999 is offline   Reply With Quote
Old February 28th, 2007, 08:21 PM   #5
FlamesFearMe
Custom User Title
FlamesFearMe's Avatar
The best tool that I can think of is Fr3dB3ar. I would never do gears without him.
FlamesFearMe is offline   Reply With Quote
Old February 28th, 2007, 08:24 PM   #6
greenmeanie
so, torque wrench is it? i have a 1/2 in drive one, not sure what # range it is though. anything else i may need before getting started?
Old March 1st, 2007, 12:15 PM   #7
Shortbus
W.H.O.R.E.-a-licious
Shortbus's Avatar
The most important thing you need is the knowledge to set gears...... that could be a book/manual, your own knowledge or a Fr3dB3ar.
When are you putting in your gears Kevin?
Shortbus is offline   Reply With Quote
Old March 1st, 2007, 12:36 PM   #8
You are supposed to have an inch-pounds scale/torque wrench to set the pinion preload, I believe.
Old March 1st, 2007, 01:58 PM   #9
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
Yep
Old March 1st, 2007, 01:58 PM   #10
Trail Junkie
iamfawkinwithyou
X2
Old March 1st, 2007, 02:04 PM   #11
GreenJeep8755
GreenJeep8755's Avatar
inch pound torque wrench for setting pinion preload and side bearing preload.
dial indicator for measuring backlash when you are done, gear marking compound or prussian blue for checking gear pattern, then knowledge of adjusting pattern without messing up your preloads and backlash.....and most of all patience if it is your first time.....an extra crush sleeve or two would not hurt if it is that type of axle, and a press makes bearing removal and install easier, but not needed if you are really careful. hope this helps!
GreenJeep8755 is offline   Reply With Quote
Page generated in 0.33247 seconds with 56 queries
