22r distributor...What if vaccum advance goes out????? FIGURED IT OUT... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 28th, 2007, 11:24 AM   #1
87yotafoo
Default 22r distributor...What if vaccum advance goes out????? FIGURED IT OUT...
If vaccum advance isnt working, will it still have good low end but once you get it up in the gears not being advancing and runnin retarded quiet a bit and not have alot of power to get it up to speed???
87yotafoo is offline   Reply With Quote
Old February 28th, 2007, 11:55 AM   #2
Thats just distributors in general. If you aren't getting your advance, then you're firing the spark when the engine is already on the downswing. Less power.
If that ends up being your issue, I have a 22R distributor which worked great. Can work out a reasonble price. Its in my to-be-ebay'd pile.
I miss that motor, with a 4:1 header and a weber 38, it pulled better than my stock 22RE does not. until a wrist pin let go.
Old March 6th, 2007, 10:05 AM   #3
87yotafoo
it works, just tested it and found it advances and retards as it should
Page generated in 0.14618 seconds with 32 queries
