SOLD - J-20 D44/D60 rear, 3.73, open - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 28th, 2007, 10:02 AM   #1
PavementPounder
PavementPounder's Avatar
Talking SOLD - J-20 D44/D60 rear, 3.73, open
The rear is from this vehicle. Centered. $150.
SOLD - The front is from this vehicle. LP, drive flanges, pass drop.
PayPal accepted.
SOLD
PavementPounder is offline
Old April 2nd, 2007, 07:45 AM   #2
PavementPounder
Bump. Buy these for your CJ or 1/2 ton FSJ!
Old April 11th, 2007, 09:10 AM   #3
PavementPounder
Bolt them into this for an insta-tow rig and cool-ass wheeler.
Old April 11th, 2007, 01:54 PM   #4
busyfixin
Balls Deep
busyfixin's Avatar
where are all the people that used to get all giddy about 3/4T axles? they are still good parts, everyone doesnt need a D60 front. what is the spring width on the front?
busyfixin is offline
Old April 11th, 2007, 02:13 PM   #5
PavementPounder
I don't happen to know. The springs should be the same width as other FSJ's.
Old April 11th, 2007, 02:42 PM   #6
busyfixin
Balls Deep
busyfixin's Avatar
i was just wondering how far offset the diff was, maybe its close to YJ width, like a 79 F-250?
Old April 11th, 2007, 02:56 PM   #7
PavementPounder
Oh, you mean the spring perch spacing. Its pretty close, but not dead-on like F-250. I think its something like 1/2" wider than YJ on each side. You can actually just bolt them into a YJ, but your shackles will be splayed outboard like this and its not really recommended:
That's a 1980-up driver-drop Waggie D44 shown, but its still the same deal. I believe 1X1_Speed_Craig has a thread someplace about this which addresses how much spring perch you have to add to each inboard side, but I can't find it at the moment. I believe the cheapo-process forpeople who didn't want to grind off and relocate the perches was add some inboard perch, fill the center pin hole with weld material, and then drill a new center pin hole in the right location. I just can't recall the correct dimension.
Monkeyevil also started this one, which has a lot of good info:
http://www.greatlakes4x4.com/showthread.php?p=505910
Old April 11th, 2007, 11:04 PM   #8
busyfixin
Balls Deep
busyfixin's Avatar
i see, sounds like its pretty close. i dont need one, as i dont have a YJ, but i just thought that it might help you sell it if people realize that it is a pretty simple swap into a YJ. you should put that in your title, good yj axle swap. anyway, free bump for a dodge guy!
Old April 12th, 2007, 05:13 AM   #9
PavementPounder
I'm not putting that in the title, because it isn't such a simple swap. Besides having to screw with the perches, the front axle is the wrong drop for a YJ and you'd have to change your transfer case. That's why I never mentioned it.
Old April 23rd, 2007, 11:57 AM   #10
orionn
orionn's Avatar
so these are both about 63" wide then?
How much rebuilding needs to be done to them befor they can be used?
orionn is offline
Old April 23rd, 2007, 12:03 PM   #11
PavementPounder
The widths are in the links, but they were looked up and not actually measured.
I've opened the rear and photographed it. The front I have not. I would expect you to be able to bolt them in and go with only attention to the brakes. By "attention" I mean you may have to replace the pads and turn the drums/rotors, as I did not inspect the brakes closely.
Old July 18th, 2007, 12:01 PM   #12
PavementPounder
Front axle is sold.
Old July 25th, 2007, 10:49 AM   #13
PavementPounder
Bump.
Old July 26th, 2007, 08:32 AM   #14
PavementPounder
Sale pending on the rear.
Old August 1st, 2007, 08:30 PM   #15
PavementPounder
Sold.
Page generated in 1.33974 seconds with 68 queries
