excel spreadsheet formula help. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 28th, 2007, 06:36 AM   #1
clarkstoncracker
lol
clarkstoncracker's Avatar
Default excel spreadsheet formula help.
I need to take column D, and subtract column F, and remove the decimal point.
I have 640 rows, and there has to be a better way then editing each formula box to =D5-F5, =D6-F6, and so on. Secretaries do not arrive until 9.
Removing the decimal is not a must, but would be awesome.
Old February 28th, 2007, 06:39 AM   #2
shawn
Resident HVAC/R Jambi
shawn's Avatar
Once you have a formula for one box, if you take your pointer to the lower right hand corner of that box, it will then show up as a + , click and drag all the way down as far as you can and it will copy all of those boxes with the same formula (but for thas specific row and column). At the end, you may have a box that appears when you let off the mouse button, and it may give you options hon how you will copy, it won't pertain in this situation. Hope that made sense.
Old February 28th, 2007, 06:40 AM   #3
shawn
shawn's Avatar
As far as the decimal, highlight the column and right click then click on cell properties, then the number tab, then select number and 0 for the decimal.
Old February 28th, 2007, 06:45 AM   #4
roll-bar Bob
roll-bar Bob's Avatar
Old February 28th, 2007, 06:46 AM   #5
biohazardbill
The Biohazards
biohazardbill's Avatar
or round it
however if you need to keep the numbers after the decimal then :
=(D6-F6)*100
Providing it is cents after the decimal
=round(D6-F6)
=roundup(D6-F6) if you need to go to the next whole number
you get the point
biohazardbill is offline   Reply With Quote
Old February 28th, 2007, 06:48 AM   #6
clarkstoncracker
lol
Shawn, you are probably the smartest person evar!
thank you so very much.
Bill, that is exactly what I needed, but I didn't think it was possible. this is going to be a great day.
Old February 28th, 2007, 06:49 AM   #7
Lothos
KD8GKB
Lothos's Avatar
You actually only need to do the subtraction. If you format the cell for the sum to not have decimal places it will automatically round it.
Old February 28th, 2007, 06:51 AM   #8
Cube
Captain of my pants
Cube's Avatar
hehe I like getting help on here too alot of good people :)
Cube is offline   Reply With Quote
Old February 28th, 2007, 06:55 AM   #9
biohazardbill
The Biohazards
Another trick for this is:
Lets say your putting this formula in column G.
As long as there are values in every cell of column F you can just double click that little box in column G Shawn was talking about and it will autofill all the way down until there is a null value in the column F. This way you dont have to pull it all the way down which can be a pain in the ass if you have thousands of records.
Old February 28th, 2007, 06:55 AM   #10
Lothos
KD8GKB
Lothos's Avatar
oh, here was my big thing I learned last year with excel that surprisingly none of the finance people knew how to do. Say you have a situation similar to CC's where you have to copy a formula down a bunch of rows EXCEPT one value in the formula remains constant, but you also need a place to change the value of the constant without having to edit every single rows formula?
Well, come to find out you can change the name of a cell in the upper left and then reference that name as a variable. IE: A1+variable=xxx and then when you do the click and drag to copy down the column its smart enough to copy the variable name whilst incrementing the other.
Old February 28th, 2007, 06:56 AM   #11
Lothos
KD8GKB
Lothos's Avatar
sweet. thats a new one for me.
Old February 28th, 2007, 07:02 AM   #12
84Scrambler
A sweet trick I learned a while back. If you have your spreadsheet filtered to see only certain data, you can't do a simple copy/paste to get that data to a new spreadsheet. Once you have the data filtered do where you only see what you want to copy, highlight the entire area you want to copy, then click Alt+; and that will select only what is visible. Then just go to your new screen and paste it in. This will not carry over any formulas, but you can just copy those and paste-special-formula to carry them over. If you filter a lot of data, this is a very handy trick.
Old February 28th, 2007, 07:05 AM   #13
84Scrambler
If you are only trying to hide the decimal vs. actually cutting it off, the properties-number-decimal=0 thing is fine. If you are actually just trying to eliminate everything to the right of the decimal, you need to use the =trunc() formula (truncate), then do the properties-number-decimal place process.
Old February 28th, 2007, 07:08 AM   #14
Archie_G
Archie_G's Avatar
what I do is pick a cell to hold the constant, and in the equation you add the '$' (ie: $A$2) - then when you copy it around, the A and the 2 never change.
Archie_G is offline   Reply With Quote
Old February 28th, 2007, 07:12 AM   #15
deuce228
Redneck Poser
deuce228's Avatar
Or just $a2 or A$2 if you only want one particular value to stay constant.
Old February 28th, 2007, 07:19 AM   #16
RyeBread
Catch the wave
RyeBread's Avatar
if you use excel a lot, from everything to the financial, to statistical to even the text transformations, I have found the following add-in a huge time saver - especially if importing/exporting/transforming data in and out of excel.
and, it's free. (or was when I put it on my various machines)
http://www.asap-utilities.com/
Old February 28th, 2007, 07:24 AM   #17
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
I learned that if you type =sum(a1+a2) it adds up the stuff in those little boxes. Fricken computers theese days I tell ya what.
Old February 28th, 2007, 07:51 AM   #18
Lothos
KD8GKB
Lothos's Avatar
I think the reason that didn't work for me is I was using the value on multiple sheets.
Old February 28th, 2007, 09:32 AM   #19
RyeBread
Catch the wave
RyeBread's Avatar
you can specify the worksheet in that absolute reference cell as well, but it may get trickier than just naming a cell/range/variable as you did it.
it would look something like this: =Sheet2!B$4 where "Sheet2" = the name of the worksheet tab
Old February 28th, 2007, 09:37 AM   #20
Lothos
KD8GKB
Lothos's Avatar
cool. Now why didn't M$ help have this when i was looking for it?
Page generated in 0.50086 seconds with 82 queries
