looking for Heim Joints locally - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 27th, 2007, 09:51 PM   #1
Default looking for Heim Joints locally
what the title says, i am building myself a set of ext. radius arms and need soem heim joints. Tractor supply in Hastings really didn't have what i wanted and Ace in Hastings didn't even know what they are.
Old February 27th, 2007, 10:23 PM   #2
locally would be SE Grand Rapids, Caledonia, Wayland, Hastings
Old February 27th, 2007, 10:28 PM   #3
wjwerdna
Toy'ota
wjwerdna's Avatar
not all so local I guess... http://www.chassisshop.com/ by silverlake dunes
wjwerdna is offline   Reply With Quote
Old February 28th, 2007, 12:03 AM   #4
PavementPounder
PavementPounder's Avatar
You're going to spend more money driving around looking for them than you would for shipping.
Old February 28th, 2007, 06:44 AM   #5
but i wouldn't have to wait for them to get shipped if i could drive there
Old February 28th, 2007, 06:53 AM   #6
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Tractor Supply
Old February 28th, 2007, 06:54 AM   #7
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
If you ordered them today, you could have them tommorow..... UPS does some amazing things, I know.
Old February 28th, 2007, 07:13 AM   #8
roll-bar Bob
roll-bar Bob's Avatar
YOU WILL LIKE THIS PAGE THEN
THESE GUYS ARE GREAT TO WORK WITH !!!
http://www.ballisticfabrication.com/
Old February 28th, 2007, 07:27 AM   #9
JINX
X2 Just used there stuff on mine.
JINX is offline   Reply With Quote
Old February 28th, 2007, 07:44 AM   #10
i want to replace my current rubber radius bushings on my ford (ttb) with slightly longer arms and a joint instead of bushings. The joints used on tractor hitches (the adjustable top links). Any farmers on here know how strong this joints are and will they hold? I can get the replacement joints ends for like $12 with my discount from NAPA. When i build them i am going to make the joints replaceable on the radius arms.
Old February 28th, 2007, 07:55 AM   #11
roll-bar Bob
WE USED THERE STUFF TO 4 LINK THE REAR OF MY BUDDIES F350 LAST WEEKEND
I LIKE HOW EASY AND NEAT THERE SHIT IS
Old February 28th, 2007, 08:41 AM   #12
mlfreund@mtu.edu
Traverse Mi
mlfreund@mtu.edu's Avatar
I got Rod inserts, misalignment spacers, and heims
FOR $190!!!
Kit Contains
Four ¾ x ¾-16 Male RH Economy Rod Ends
Four ¾ x ¾-16 Male LH Economy Rod Ends
Four ¾-16 RH Jam Nuts
Four ¾-16 LH Jam Nuts
Sixteen 3/4 to 5/8 High Misalignment Spacers
Four 3/4-16 RH Weld-In Bungs
Four 3/4-16 LH Weld-In Bungs
http://www.qscomponents.com/FourLinkRodEndKits.html
mlfreund@mtu.edu is offline   Reply With Quote
Old February 28th, 2007, 08:47 AM   #13
PavementPounder
Tractor parts belong on tractors.
Old February 28th, 2007, 08:54 AM   #14
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
X2
Summitracing has a good selection and usually next day. I would get atleast get a 7/8" heim or bigger.
Old February 28th, 2007, 09:00 AM   #15
gotsand?
sie sehen mich rollin ...
gotsand?'s Avatar
Location: New Era, MI --- "We passed BFE 35 minutes ago."
Send a message via Yahoo to gotsand?
did you check cascade 4wd?
gotsand? is offline   Reply With Quote
Old February 28th, 2007, 11:38 AM   #16
no, not yet thinking of dropping by their on my lunch
Your right nobodies ever taken a part designed for something else and adpated to work for their application.
Old February 28th, 2007, 11:46 AM   #17
Motorcitydak
Merkin salesman
Motorcitydak's Avatar
Send a message via AIM to Motorcitydak
just buy the johnny joints. You can get em like i did with a 1.25 inch threaded shank and they take a 9/16 bolt. They are 40 bucks plus 2 for a jam nut and 14 for the tube adapter, I like the ones mad4wd sells. They fit into 1.5 ID tube.
Motorcitydak is offline   Reply With Quote
Old February 28th, 2007, 12:34 PM   #18
PavementPounder
They have, and they have discovered why you don't do that. Besides the strength issues, there are probably legal considerations of having farm implement parts on a highway-driven vehicle if you have a failure and someone decides to investigate the odd-looking non-stock parts.
If this was on a trail-only vehicle that was towed to the playground, I would have a different opinion.
Old February 28th, 2007, 01:11 PM   #19
YEP i will admit it does see a mile here and their of pavement from one trail to the other, or the gas station .5 mile from my house.
I can except constructive critism when theirs an explantion as to why. Not a "just don't do it" answer.
All i was looking for was a yes or no as to the strength of the part. (thanks for answering it, i'll look for somethin else or order something)
Old February 28th, 2007, 02:23 PM   #20
dune coon
do work
dune coon's Avatar
x 2 on the jonny joints. If you get them from JKS, you can get 'em for 39.50/each with jam nuts. Then, just get some tube inserts (or get tube tapped)
dune coon is offline   Reply With Quote
Page generated in 0.48730 seconds with 83 queries
