Tractor Axles - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 27th, 2007, 01:48 PM   #1
Hubbler
Hubbler's Avatar
Default Tractor Axles
So anybody ever heard of someone or used tractor axles for a mudder? I've been lookin around on the web and can't find too much. I'm buildin up a new rig and I wanna go big. As in like tractor tires and/or some 46" Baja Claws. I'm prolly gonna use a blown 502 for a power plant if my buddy still has it and I dont wanna spend a lot of money buildin up one tons to hold it. I can get a whole tractor drivetrain with tires for cheap. I know there will be a lot of fabricating but i think it would be pretty cool. So if nebody knows or heard of this let me know thanks.
Hubbler is offline   Reply With Quote
Old February 27th, 2007, 02:09 PM   #2
groundhog
groundhog's Avatar
I have seen pictures of them, but the more common one I have seen is running on 2.5ton rocks with tractor tires. What is the gearing in the the axles, that might become a issue tractors dont go very fast.:tonka:
groundhog is offline   Reply With Quote
Old February 27th, 2007, 02:16 PM   #3
roll-bar Bob
roll-bar Bob's Avatar
MOST OF THESE GUYS WHEEL TRAIL RIGS AND DD'S TRY THIS QUESTION ON http://.com/ THERE ARE MORE HARD COR MUDDERS THERE
Old February 27th, 2007, 06:03 PM   #4
Hubbler
Hubbler's Avatar
I dont know what the gearing is yet. I'm up at school and was gonna check all that out when I go back for spring break. I just wanted to ask around so i wouldnt be wasting time.
I will check the site out Thanks.
Old February 27th, 2007, 09:21 PM   #5
noodles
give 'er sh*t ay?
noodles's Avatar
other than the fabircating i think it would be a good idea. I dont know what the rear end ratios are but some of them are pretty damn low i know that much. i would have to say in the 8's:1
Old February 27th, 2007, 09:44 PM   #6
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
For only 46's run 2.5 ton rockwells, plenty of parts available for them. If you man up to 60" or bigger go to the 5 tons. Just so happens to be a set of 5 tons on
Old February 27th, 2007, 10:14 PM   #7
xj_man_646
Wheeler-less
xj_man_646's Avatar
Send a message via AIM to xj_man_646
yea hubble, i'd run some 2.5 tonners. stock with 6.72 gearing, and welding them pretty much makes them bulletproof.
xj_man_646 is offline   Reply With Quote
Old February 28th, 2007, 01:03 PM   #8
Hubbler
Hubbler's Avatar
Yea I was thinkin of going rockwells but I can get the tractor axles cheap. As in my buddy wants me to come and get it off his property for no money. So thats why i wanted to know. I also found a place down in Ohio that has beat up unimogs for 2 to 3 grand.
Old February 28th, 2007, 07:53 PM   #9
cjaholic
(o )( o)
cjaholic's Avatar
I worked for Kubota when I lived in Fla. First of all you would need two large front axles, the width of front and rear are different. To get a good width front axle thats strong enough it would have to come from at least a 80 HP tractor.
Most of them are portal axles w/ 1:1 ring and pinnion and about 7.3:1 in the hubs. Its easy to find them w/manual diff. lockers, cable activated. Most have square tubes, would make the fabrication easy.
I have seen alot of the front axles brake, most of the time from to much weight on them. There easy to work on.
And the not so good:
No breaks on them. Price to buy and repair them is high. Whole axle is cast. No upgrades or options.
Just my 2 cents.
cjaholic is offline   Reply With Quote
Old March 1st, 2007, 03:11 PM   #10
Hubbler
Hubbler's Avatar
hmmmmm, thanks for the input. I'll look into it more when i go back home.
Old March 1st, 2007, 03:27 PM   #11
roll-bar Bob
Just my 2 cents.
I THOUGHT ABOUT TRYING TO GET A USED SET OF THESE AXLES TO BUILD FROM THEY EVEN HAVE REAR STEER
BUT I DONT KNOW WHERE YOU COULD GET THEM AS CHEEP AS ROCK WELLS
Old March 2nd, 2007, 05:35 PM   #12
Hubbler
Hubbler's Avatar
You could try nolans which is just north of Lapeer on M24. Also there is another huge junk yard i always see when I am goin up 75 between bay city and west branch I think.
Old March 2nd, 2007, 06:03 PM   #13
cannaert
No more Jeep
cannaert's Avatar
There is a place in My the Milford on Buno Rd right by the rail road tracks that deals in heavy equipment. You can get Rockwell's and Planetary axles pretty cheap
Old March 9th, 2007, 08:44 AM   #14
roll-bar Bob
http://.com/forum/index.php?topic=17452.0
THERE YOU GO THAT IS WHAT YOU NEED !!!!
Old March 9th, 2007, 10:01 PM   #15
Pre4runner
Bike Dude
Pre4runner's Avatar
Sky trac axles! I've played with the ideas of using some of them. portal low gears, not sure how they would hold up to hp but lots of clearance
Old March 22nd, 2007, 01:23 PM   #16
nick_n_ii
nick_n_ii's Avatar
Send a message via Yahoo to nick_n_ii
I fyou follow Rock Crawling there is that old overalls guy he runs them and never seems to break.. Just my $.02
nick_n_ii is offline   Reply With Quote
Old March 22nd, 2007, 01:41 PM   #17
Bones
Bones's Avatar
Team Lovell Engineering
He is also one of the best at rockcrawling.. always finishes in the top 5 in werock, usually first or second.
These are some pics I took of his rig at WeRock Columbus. He now designs his own tcase, which is air shifted at a flip of a switch
I didnt see anyone make this gate... he was the closest though, and put on a great show
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old March 22nd, 2007, 01:52 PM   #18
roll-bar Bob
I Seed Him On Tv !!!!!
Old April 8th, 2007, 11:50 AM   #19
signman
Big problem with tractor axles is the direction of drive, thats why everyone uses rockwell,s, ftr or rear doesn,t matter. That is one of the problems with the old GMC 6x6 axles frt drives backwards, 3 out puts on t case, frt is reversed, 2 for rear, no low range, 2 rear shafts,one goes over lead diff. 2.5 ton axles are ok but 5 tons are bullet proff, but heavy (2500#) per diff you can thrash them hard, you can find 10.00 gears in the wreckers.
signman is offline   Reply With Quote
Old April 8th, 2007, 11:55 AM   #20
signman
Took a second look at his frt looks like a ZF axle used in all sorts of ind apps, Chandler used this in some of his later stadium trucks, tough and light weight under 1,000# with the planatry ends
Page generated in 0.36784 seconds with 83 queries
