87 yota 4x4 22r.....runs good but slow and no power - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 26th, 2007, 05:52 PM   #1
87yotafoo
Default 87 yota 4x4 22r.....runs good but slow and no power
it starts and runs fine, but everywhere you go it has to be pretty much floored and tops at maybe 55ish and takes some time and gotta rev it out to get there in early gears.
Has no power to pull itself up hills..... Timing im sure is close, motor is pretty much fresh, low miles block and lower miles head and new HG and stuff...Carb problems? vaccum lines? Like i said it starts and idles and runs decent, no sputtering or backfiring. But just sucks, Runs good low end, like 1st 2nd, still floor it to go anywhere quick, Its fine when playin in 4wd and stufff since only use lower gears but road ridin sucks *$)
Any ideas before i efi this truck and waste more money.....
87yotafoo is offline   Reply With Quote
Old February 26th, 2007, 08:08 PM   #2
What tires and gears do you have?
Old February 26th, 2007, 08:23 PM   #3
hman1991
hman1991's Avatar
Send a message via AIM to hman1991
he has stock gears and 31's
hman1991 is offline   Reply With Quote
Old February 26th, 2007, 10:05 PM   #4
Pre4runner
Bike Dude
Pre4runner's Avatar
whats has all been done with the motor? was this rebuilt new head, explain?
Old February 26th, 2007, 10:10 PM   #5
87yotafoo
just a low mileag block and head and just installed new headgasket when installing. Nothing else done to it..and timing chain and guides
Old February 26th, 2007, 10:14 PM   #6
Rattler
Home Sweet Homicide
Rattler's Avatar
My old 22RE XtraCab did the same thing. When I pulled the sparkplugs and replaced them. I found out how much better it ran with plugs that had electrodes.
Old February 26th, 2007, 10:44 PM   #7
Pre4runner
Bike Dude
Pre4runner's Avatar
I was going to say the same thing. Before Tyler bought the red toy and it was running it had a similar problem, Plugs were to blame
Also check you timing chain and make sure you have it correct and that your not off by a tooth. I did this the first time i did my head gasket. Got it to run fine but it had no top end
Old February 27th, 2007, 04:56 AM   #8
87yotafoo
ive thought about the chain being off a gear, but how you actually tell on those, i thought i had marks lined up...Anyone know of the actual mark to use, maybe i was misinformed?
It also diesels here and there when i shut it off....
Old February 27th, 2007, 10:18 AM   #9
Yeah, x3 o nthe chain off a tooth. Retarding/Advancing the cam timing moves the whole powerband up/down. In this case, it also screws with ignition timing. The dieseling also points to timing being off..
Old February 27th, 2007, 11:32 AM   #10
87yotafoo
but if it was off a tooth on cam timing, either direction will it still run decently and start good??? besides you have to have it to the floorboards everywhere you go....
Old February 27th, 2007, 03:18 PM   #11
nmeinc
Parts Galore Spokesmodel
nmeinc's Avatar
Yep, sounds like your a tooth off
nmeinc is offline   Reply With Quote
Old February 27th, 2007, 03:26 PM   #12
Yeah, it probably would in one direction, the other, I'm not sure.
On plenty of engines, you can buy adjustable cam gears, although you rarely adjust more than about 4 degrees. Usually being off one tooth is like 6-10 degrees, depending on the number of teeth.
It usually moves the powerband up and down a certain amount, so its not uncommon to see a big gain on the bottom end but a total loss of higher rpm power. Did you have to move the distributor a lot to time it? It would be off by however much your cam is off.
Old February 27th, 2007, 09:23 PM   #13
darkteg94
darkteg94's Avatar
Yeah. Get that thing taken care of. If you get the timing fixed still gonna do the EFI swap anyway?
darkteg94 is offline   Reply With Quote
Old February 27th, 2007, 10:17 PM   #14
87yotafoo
messed with it for abit today, changed cam timing a tooth in both directions, seemed to be worse then before and messed with changing the ignition timing also while in both changed teeth. So gonna do some more research and see.....
Seems to have some play when you turn the crank pulley bolt before cam gear turns
Anyone know where the notch in the crank pulley has to be for tdc? i know there is a little nub on the back side of the cam gear that lines up with arrow.
Old February 27th, 2007, 10:34 PM   #15
Rattler
Home Sweet Homicide
Rattler's Avatar
Where are you located?
Old February 27th, 2007, 10:53 PM   #16
87yotafoo
kalamazoo area MI
Old February 28th, 2007, 10:54 AM   #17
87yotafoo
since i messed with timing, both cam and ignition.....im leaning to wonder if the vaccum advance on the distributor isnt working? Since it runs decent low end and low gears, wonder if its not advancin the timing correctly and makin it lack power up higher....??????
Old February 28th, 2007, 11:06 AM   #18
artistic_gore
I own @ halo
artistic_gore's Avatar
Send a message via AIM to artistic_gore
Am I a million miles off or could this be a clutch issue?
artistic_gore is offline   Reply With Quote
Old February 28th, 2007, 11:22 AM   #19
87yotafoo
new clutch, installed it last summer....That holds up great, wheeled the crap out of it and still do....just cant go down road very good to get anywhere
Old February 28th, 2007, 11:23 AM   #20
He'd know if it was a clutch issue, methinks. You'd get to the upper rev range and its rev way up as it started to slip.
At least mine did.... last year... 15 minutes before loading onto the trailer for a 5 day wheeling trip.... fastest clutch swap I ever did....
If its got good low end but no top end, you've got some issues somewhere.
Incorrect base timing
Not enough timing advance (I'd check it with a timing light to see how its advancing through the rev range)
Bad cam timing
clogged fuel line / filter / jets
Plugged exhaust / cat
Plugged air filter
99% its one of those things.
Page generated in 0.40004 seconds with 83 queries
