Goddamn heater - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 20th, 2006, 09:58 PM   #1
Gunsworth
Gunsworth's Avatar
Default Goddamn heater
Alright, I tore the controller out and all cables are doin their job, fuse is fine but I get no heat or blowing unless Im goin over 40 or so.
Also It sat for 2 months and when I started it up, the heat was somehow working. Then I shut it off and it didnt owrk again. It hasnt worked in the last 2 years other than that one time.
WTF?
Old January 20th, 2006, 10:10 PM   #2
shawn
Resident HVAC/R Jambi
shawn's Avatar
Verify you have 12 volts going ot the motor with the heater on high. sounds like you need a new blowe motor.
Old January 21st, 2006, 12:35 AM   #3
GMCsonoma94
1 wheel peel
GMCsonoma94's Avatar
Send a message via AIM to GMCsonoma94
what do you mean unless your going over 40? does it start blowing then? i think shawn is right tho sounds like a blower motor, not to difficult to mess with tho.
GMCsonoma94 is offline   Reply With Quote
Old January 21st, 2006, 08:23 AM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
not working unless the engine is reving 40mph? sounds like your water pump took a crap. the impeller tabs have all rotted off and you have reduced volume in the flow capability of the cooling system. put a pump on it and see how it does.
Yetti
Old January 26th, 2006, 04:32 PM   #5
Gunsworth
Gunsworth's Avatar
My water pump only has about 5K on it, I originally changed that thinkin it was the prob.
The heat blows harder the faster I go. Guess Ill look into the blower motor, if I can find it...
Old January 26th, 2006, 04:43 PM   #6
shawn
shawn's Avatar
Yup, the blower is not blowing. Need to check to see if you got any juice at the motor.
Old January 26th, 2006, 07:58 PM   #7
BigBlkYJ 355
U-Joints Fear Me
BigBlkYJ 355's Avatar
the only reason ur getting heat at speeds is because air is being forced into the cabin through the front vent. like they all said, blower is prob bad.
Page generated in 0.20837 seconds with 44 queries
