Woofer Feedback in 01 TJ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 20th, 2006, 06:14 PM   #1
shawn
Resident HVAC/R Jambi
shawn's Avatar
Default Woofer Feedback in 01 TJ
So my TJ is having some engine feedback through the factory woofer in the center counsel. I think it may have happened after a spark plug changed, but I am sure I used Champion plugs. Anyone else have this problem? You only hear it at idle. Raise the RPMs and the noise goes away.
Old January 20th, 2006, 06:49 PM   #2
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Plug wires will cause this if they are poor quality, or if the sheilding is bad.
JcrOffroad
Zoom Zoom!
Old January 20th, 2006, 07:24 PM   #3
going-strong
'96 360 sport 4x4
going-strong's Avatar
my family used to own our own repairshop, we refused to stock champion spark plugs because we had so many complaints about them...we heard about things like this all the time...monkeyevil is correct. your wires might be cross fireing, try to reroute them or put wire loom around them
going-strong is offline   Reply With Quote
Old January 20th, 2006, 08:53 PM   #4
shawn
shawn's Avatar
Well, that is good input, but this ain't got those plug wires. It's an ignition rail system, because it's an 2001. So, still may be the plugs then.
Old January 20th, 2006, 10:22 PM   #5
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Get Bosch's or NGK's or something.
Old January 20th, 2006, 11:26 PM   #6
Mclovin
"The Situation"
Mclovin's Avatar
Originally Posted by GreaseMonkey
Get Bosch's
and call me when u break down and ill come tow you back for a small fee..
I WOULDNT EVEN RUN BOSCH'S ON MY F-ING LAWNMOWER !
Old January 31st, 2006, 09:57 PM   #7
Kawierider
Kawierider's Avatar
Ground issue with the sub ?
Just another option if the plugs dont fix it.
Old February 1st, 2006, 01:55 PM   #8
JeepMann
10 Years
JeepMann's Avatar
Send a message via AIM to JeepMann
x2
I had bosch's in our wj and it ran like sh-t but after putting the champions back in it ran like new again.
JeepMann is offline   Reply With Quote
Old February 1st, 2006, 03:39 PM   #9
GreaseMonkey
Pew pew!
Never had a problem with Bosch's or NGK's. Ever think about the fact that both of you might have gotten the wrong heat range for your vehicle by accident?
Old February 1st, 2006, 04:47 PM   #10
shawn
shawn's Avatar
No, Bosches had a bad run of plugs for a while. The electrode tip was falling off and scoring cylinder walls or buring up valve seats. By now I am sure they have fixed that problem with their platnum plugs, but I will probalby stay away from them.
Anyway, anybody else have any new ideas for this probem? We have beat to death the spark plug issue.
Old February 1st, 2006, 06:31 PM   #11
Bones
Bones's Avatar
simple, you need a V8 swap
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old February 1st, 2006, 06:48 PM   #12
going-strong
'96 360 sport 4x4
beef up the wires on your alternator(hot and ground), somtimes amplifers (even factory amps, and the ones built into radios) can pickup noises from your alternator
Old February 1st, 2006, 07:51 PM   #13
shawn
shawn's Avatar
Yeah, that's just what Melinda needs. :miff:
She ins't feeling like she needs to compensate for anything :tonka:
Old February 1st, 2006, 07:57 PM   #14
yellowjeeperman
The N3rd
yellowjeeperman's Avatar
For some reason i dont think simple and V8 swap should be in the same sentence
yellowjeeperman is offline   Reply With Quote
Old February 4th, 2006, 12:14 PM   #15
BigBlkYJ 355
U-Joints Fear Me
BigBlkYJ 355's Avatar
amen to that
Old February 11th, 2006, 08:51 AM   #16
Fatty Matty
Fatty Matty's Avatar
My 03 tj came with champions from the factory, and I didn't have any problems like that, ever.
I HAVE had problems with the factory cd player, and the sub. Both have been replaced twice. That option was a waste of money.
'12 JKU
'14 1500
www.midwest-abs.com
Old February 11th, 2006, 09:12 AM   #17
shawn
shawn's Avatar
We've been through 2 radios in this thing, but not a sub. What happened to your sub?
Old February 11th, 2006, 09:24 AM   #18
biohazardbill
Guest
Posts: n/a
Did you get this fixed... it is a bad ground... end of story.
Old February 11th, 2006, 01:21 PM   #19
Fatty Matty
They sounded blown, and the dealer said they were blown.
I don't listen to any really bass-heavy music, but if you saw one out of the console, you would see how flimsy they really are.
Since I ordered my jeep, it still irritates me to this day that I dropped the money ($350, I think) on the "350 watt 7 speaker premium sound system". The truth is, it really only puts out about 80 watts max, and 50 of it is sucked up from that shitty 6.5" sub.
Your run of the mill $100 basic pioneer CD deck is years ahead of the stock CD deck. Same goes for any basic 2-way speaker you could buy. All that adds up to way less than the factoy stuff, and sounds a ton better.
'12 JKU
'14 1500
www.midwest-abs.com
Old February 11th, 2006, 04:16 PM   #20
shawn
shawn's Avatar
Well, I only hear it through the sub, and it's not your normal whiny feedback, more like a sta sta sta sound. I've changed plugges twice with no luck. Maybe I'll just check the ground and maybe put a filter on the factory amp power wire.
Page generated in 0.35750 seconds with 83 queries
