14 bolt - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 24th, 2007, 03:46 PM   #1
troyjeeper
Default 14 bolt
alright u gear head i am trying to find out what year my 14 bolt is i pulled diff cover and found these numbers on 1 GM 3977334 then 10 41 7 76
so i hope some one hear can tell me what year it is or what the numbers mean
thanks guys
troyjeeper is offline   Reply With Quote
Old February 24th, 2007, 03:55 PM   #2
BMFmike
meh.
BMFmike's Avatar
Is it a 10.5 inch ring gear or 9.5 inch?
The only differences inside the housing on a 10.5 is 88 and down, 89 and up. 88 and down uses a smaller inner bearing on the pinion, where the 89 and up uses a larger bearing. So if you have it apart, or are going to take it apart, check the part number on the bearing, I cant remember it off the top of my head, but you can call a parts store and cross reference it.
Edit: Didnt see the numbers you posted, I am sure somebody can help you with those.
Old February 24th, 2007, 05:22 PM   #3
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
GM 3977334 = the part #
10 41 = the number of teeth on the pinion and ring gear
7 76 = it was built in July 1976
Old February 25th, 2007, 09:40 AM   #4
troyjeeper
thanks guys
Page generated in 1.11733 seconds with 35 queries
