Not a Zuk but A Geo...Solid axle info anyone? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 23rd, 2007, 06:16 PM   #1
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Default Not a Zuk but A Geo...Solid axle info anyone?
Anyone have any web pages saved for lifts or solid axle conversions on a Geo Tracker?
Looking for budget stuff, not high dollar links and coilovers.
Old February 23rd, 2007, 07:43 PM   #2
hman1991
hman1991's Avatar
Send a message via AIM to hman1991
heres a good post over on zuwharrie.
http://bbs.zuwharrie.com/content?topic=24216.0
to do it on the cheap throw a sammy axil under it with the diff out of your tracker. 2 inch wheelspacers and sammy leafsprings or yj depending on how high you want it. but there r alot of different setups on the link. like 9 pages.
hman1991 is offline   Reply With Quote
Old February 23rd, 2007, 10:03 PM   #3
ouchman
ouchman's Avatar
Send a message via Yahoo to ouchman Send a message via Skype™ to ouchman
3" suspension lift on 31s
support the sport- www.GLFWDA.org - member
Dear Travelers,
You won't see London and you won't see France, until we see your underpants!
Sincerely, TSA Officers
ouchman is offline   Reply With Quote
Old February 24th, 2007, 01:07 AM   #4
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Holy crap.....it's an ATV winch!
Old February 24th, 2007, 01:08 AM   #5
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Old February 24th, 2007, 01:43 AM   #6
Quagmire
I can has layinframe
Send a message via Yahoo to Quagmire
GEOBOY is three pics down
Google first.....ask questions later
Actually, the new rule of thumb is you should make your tires bulge slightly more then skooterbuilt when he's wearing his tight ladies pants
Quagmire is offline   Reply With Quote
Old February 28th, 2007, 10:06 PM   #7
I'd re-evaluate using an axle swap, and go with an IFS linkage.
You need to address the steering issues...the box gets replaced and new tie rods and all that. Then there is the brake work that has to be converted. Don't foget about fabbing up the shock mounts and what not...and buying the shocks.
Then you have to adapt the steering lines to fit the new box installed. And adapt the steering shaft to mate to the new box.
Going to have to do something with the driveshafts...even the 3 inch lifts need some kind of spacer or adapter...dunno what it does but you'll have to mod the shafts to work with the new axle flanges.
That's not including finding and buying the sami axles, leafs, u-bolts, and plates. I would guess that if you got a set of axles from a bone yard, they would probably need all new brakes put on them...so more money.
Then the metal you will need to weld in to make the spring mounts and front crossmember. Bolts, nuts, bushings, and shackels.
All the little things that it seems people don't think about when doing something like this. It's not that it can't be done...but simply saying it's cheaper is, IMHO, incorrect. If you were very thrifty, and could wait till the right deal came along for this or that part, then maybe. But that isn't reality for most.
:tonka:
Old March 1st, 2007, 07:20 AM   #8
Depending on your wants/needs, I'd go with a set of Toyota axles(good up to 39s if you build them right), or find a widetrack CJ dana 30 front(maybe up to 33s). Or waggie dana 44s front and rear.
Check out the toyota truck forum on pirate4x4, the FAQ has tons of Toyota info. Toy front axles are 55.5" WMS/WMS, but can be made to be 58.5 with a swap to the IFS hubs. Jeep WT dana 30s are also about 56" wide, and would be lighter than a toy front.
Budget wise, leaf springs are your friend, a pair of stock YJ or rear Toyota(80s era) springs would probably be plenty for SOA configuration (Toy axles are SOA, Dana 30s as you know are SUA), or wagoneer springs for SUA. The Toy and Waggie springs have an offset pin which will help your approach angle. Either way, your front shaft isn't huge, I'd go front mounted shackles on them.
Toy frames are wider than Cj frames, so the pads are about 1.5" wider apart, I believe. But they are very close to Sami frames, so perhaps close to trackers.
Or, the Sami axles as noted, find someone who's going bigger and pick up a front end. 31s, even 33s could survive if its wheeled carefully. Get upgraded birfields or rings or whatevers available for Zuks these days.
Stock Toy birfields would probably hold up to decent tires in a tracker. (modifield toy birfs are strong as dana 60s)
What kind of tracker, how high of a lift, and what size tires are your plans?
Old March 1st, 2007, 03:52 PM   #9
scottie
Eye candy
scottie's Avatar
well you can get birfield rings for stock samurai axles, but then you break the shaft and not the joint, so i'd just leave the birfs stock and keep spares.
You can modify them though and put different side gears in, and run larger shafts, and that can hold up to 33's supposedly. But as cool as Suzuki's are, i just don't see the point in putting lots of money into the axles, when 44's and toys are around.
Old March 2nd, 2007, 01:28 PM   #10
Its too bad Bobby Long doesn't make zuki axles/birfs. That would be a nice upgrade.
Old March 6th, 2007, 11:30 AM   #11
jimmyroyse
webwheeler
jimmyroyse's Avatar
newfield's
http://www.izook.com/tech/samurai/dr.../newfields.htm
jimmyroyse is offline   Reply With Quote
Page generated in 0.32694 seconds with 56 queries
